| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
drec - did you mention "new springs"?
as the RD11 could easily be over 30yrs old (not necessarily a bad thing - I'm well over that age, and although more compliant that when new, my springy parts still mostly work), where did you get them? If you haven't had experience playing with adjusting springs on this table, it's not likely too much difference from the LP12, Fons, etc.: the tightness of mounting bolts, condition of rubber grommets and rotation of springs in relation to each other is as important as their individual torque load. It's virtually essential to fabricate some type of rig that raises the plinth 18" or so about a work surface and allows you easy access - it's very important it's dead level, both when adjusting the springs, and when playing
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#12 |
Thanks! I'm thinking of my options re balancing it over the work area.
I just bought a set of Linn springs, brand new, off Ebay. |
#13 |
drec,regarding your springs.
The Ariston is slightly different to the Linn (i think) in that the Ariston has an indented washer fitted between two flat washers between the adjusting nut and the lower grommet.This is a mixed blessing in my view as on the one hand it allows you to 'cant' the springs over to one side to aid in getting the circular armboard central in the cutout,but at the same time can end up making the suspension 'catch' slightly unless you've get endless hours to 'beaver' away at it.. I've spent ******* hours mucking around with this setup, and when i got my new Linn springs etc i decided to do away with the indented washers. I dont always now get my armboard perfectly central in the cutout,instead i concentrate more on getting the platter level and making sure the springs dont rub on the stainless steel bolts.This has given me much more consistent results with obtaining the right amount of 'springiness' in the suspension and as a result much better sound.I also fitted some smooth plastic tubing over the stainless steel bolts,and added a nylon washer between my locknuts and flatwashers.Every little bit helps. |
#14 |
Thanks for the tips. The notice to pick up the springs and tonearm came in today... getting started on the project once I've gotten them is another story!
Best, Andre |
| ariston RD11, Linn Vector-like DIY | bonzini | Analogue Source | 96 | 17th April 2010 08:30 PM |
| request for Ariston RD11 E/RB250 armboard | drec | Analogue Source | 1 | 31st December 2008 05:40 AM |
| My discovery | Ric_LV | Subwoofers | 1 | 29th June 2006 10:10 PM |
| A question about building a sealed box (acoustic suspension). | piro | Multi-Way | 3 | 8th March 2005 08:51 PM |
| A weight vs. linear weight | gary f | Multi-Way | 1 | 2nd April 2004 01:23 PM |
| Page generated in 0.07667 seconds (77.89% PHP - 22.11% MySQL) with 11 queries |
