Old 21st October 2008, 11:41 AM   #11
Ok. If you have controlled 4 TD-125 with the same voltage, it's maybe a wrong indication or a part (transformer ?) derivates with time (dielectric ?).
Thanks for you help, it seems that everything is now fine on my turntable.
Damien.
Old 22nd October 2008, 03:41 AM   #12
kevinkr's Avatar
Damien.
It could well be that there is a typo in that schematic, or that indeed the transformer specification was changed after that particular drawing. The capacitors are 25V types so there is some margin. IIRC I may have replaced mine with 35V types, but as long as it goes no higher it should not be an issue.
www.kta-hifi.net
Help required for using a FDD motor as a turntable motor. binspaul Analogue Source 5 13th May 2009 03:59 AM
Lambda motor vs. XBL^2 motor vs. any other motor Thinkcat Subwoofers 16 23rd December 2008 06:23 AM
DIY TT: motor, motor PS, platter speed measurements dice45 Analogue Source 52 9th May 2006 01:07 PM
DIY TT motor FrancoB Swap Meet 3 18th May 2005 08:43 AM
dc motor dionysio Analogue Source 1 3rd May 2004 01:09 PM
Page generated in 0.06496 seconds (70.89% PHP - 29.11% MySQL) with 10 queries
