| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
I would (and have done) use either Epoxy for a non compliant fixing or Contact adhesive (like Thixofix) for a more compliant fixing. I wouldn't use silicone myself unless you want an extremely compliant mount - in which case i would use thin spacers between the materials whilst the silicone sets.
#12 |
Hi All,
Thanks for the suggestions. I am not sure if i want compliant bonding between the layers, some advice on this would be great. I held the Walnut plinth (top layer) and did the knuckle wrap test, i then lay the walnut on top of the granite and did the same. With the granite made a massive difference, so i just want them together, but i don't know if i want compliant or non compliant bonding??? Has anyone tried hardwood and granite? The reason i would like non permanent is, i may in the future upgrade the platter and bearing, but would like to keep the walnut plinth? Please keep your ideas coming, i really appreciate it. Ian |
| first amp advice | prezden | Class D | 2 | 18th November 2008 10:05 PM |
| TT advice??? | geordie | Analogue Source | 2 | 30th September 2007 04:04 PM |
| Advice for an amp | wyomoose | Subwoofers | 1 | 12th February 2007 08:07 PM |
| New to DIY, looking for advice | flubhubber | Multi-Way | 1 | 14th November 2005 03:48 PM |
| Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice | moving_electron | Chip Amps | 0 | 16th February 2005 12:37 AM |
| Page generated in 0.06712 seconds (68.95% PHP - 31.05% MySQL) with 10 queries |
