Old 12th September 2008, 04:44 PM   #1
c3conv is offline c3conv  Philippines
Default DIY tone arm vs rega?
Has anyone diy tonearm outperform rega's tonearm? I am hopping there are some who has done a great job.
Old 12th September 2008, 05:38 PM   #2
My upside down ladegaard style air bearign arm took about a day to make, cost about £30 and beats the hell out of any rega arm, probably better than any rega based arm at all no matter how modified.
In fact, ill even go as far as to say it probably beats any pivoting arm at all.
I have no evicence to back this up except a couple of reviews of an identical arm which were very favourable. They said it was up there with £5000 arms!
I do know for definate that it is in a different universe to a stock rega arm though as thats what i had before.
Beating a rega arm isnt hard
This arm is what i built first. It very easily outshone the rega.
http://www.aiko.com/roscoe/airbearingarm.html
Then i saw this version so i built one of these, much better than the first version
http://cgi.ebay.co.uk/NEW-TERMINATOR...d=p3286.c0.m14
Old 12th September 2008, 05:39 PM   #3
I seriously have no idea why anyone bothers with pivoting arms anymore, ill never go back.
I may try a schroeder (sp) clone one day though.
Old 13th September 2008, 01:43 AM   #4
WOW, heavenly sent. Can you please post some close up pictures on how you did the 2nd arm. I can get a lot of spare aluminum. Any specific type of aluminum?
Old 13th September 2008, 08:47 AM   #5
Everything you need to know is in the first link
If theres antything specific you want to ask then go ahead.
Old 14th September 2008, 08:16 AM   #6
Nanook is offline Nanook  Canada
Nanook's Avatar
Default beating a Rega is easy...
but beating an SME is a little tougher. I haven't managed that yet, but I have hit one in the ball park for very little money.
The upside down air bearing arm looks pretty good...
stew -"watch out where the Huskies go and don't you eat that yellow snow"--Nanook died of starvation 8 mos after the movie was made
Old 14th September 2008, 10:24 AM   #7
Depends what SME your talking about
http://www.trans-fi.com/terminatortonearm.htm
Old 14th September 2008, 12:32 PM   #8
webby is offline webby  United Kingdom
Hi Graeme,
I have built one of the original Ladegaard arm like you, but how did you make the Upside down version. I cant work it out from the pictures? where did you buy the materials from and did you use the same pump?
Cheers
Ian
Old 14th September 2008, 02:48 PM   #9
Yep, same pump.
Most of the materials were from B&Q, with a bit of plastic from the local suppliers. Mine is a bit simpler than that one.
What cant you work out? Its exactly the same as the normal ladegaard, just upside down. The mounting area looks comlicated but all it is is a way to adjust height and level, theres plenty of ways to do that.
Old 14th September 2008, 02:50 PM   #10
here's mine.
The whole TT is just a lash up at the moment though, will be remade properly soon.
rega p3 platter on a p1? jicas Analogue Source 8 17th January 2008 03:57 PM
Rega P3 upgrades neil_kaye Analogue Source 7 27th September 2007 10:17 PM
Rega Io Dac - which chipset/op-amp used? mickie Digital Source 0 20th June 2007 12:36 PM
rega p2 hum mpmarino Analogue Source 7 20th August 2006 03:38 AM
Page generated in 0.11394 seconds (82.09% PHP - 17.91% MySQL) with 11 queries
