Old 4th September 2008, 03:10 AM   #1
sw3Ex is offline sw3Ex  Croatia
Default Mine Technics 1210 MK2 is broken :( Plz help!
http://www.youtube.com/watch?v=YjvzU3DFBL8
Here is video... I have replace an6680, an6675 and crystal, but same problem again
Please help
Old 4th September 2008, 03:28 AM   #2
burbeck is offline burbeck  United Kingdom
hi
i have had this problem with that model, inttermitant speed and speed suddenly increasing.
Around the motor there is a sensor /servo coil, this is a printed flexible circuit board coil that terminates in 2 vertical pins/wires soldered to the main board, at the point where the wires attach the circuit becomes broken. you will have to take out the main board to inspect this part and then it is not ovious. on one occasion the part measures ok but when assemled was causing problems, (crack in the coil).
the good news is that this part is availible as a spare from technics.
also do a search on this forum for this model for more info
regards
bob
Old 10th September 2008, 08:29 PM   #3
do you have maybe any picture of the part? tnx
Old 11th September 2008, 04:33 AM   #4
hi there,
the part is described as FG coil assembly, number is SFM2172-01A
the service manual can be had at vinylengine.com
the pages are 12 and 13. drawing reference 7.
i would recommend that this work be done by a experienced technician, this part is very delicate when soldering, there is quite a bit of dismantling required and there is also mains is present on the pcb.
good luck
regards
bob
Old 23rd September 2008, 04:04 PM   #5
bump
regards
bob
Old 3rd July 2009, 02:54 PM   #6
I have changed FG Servo coil, but same problem again
plz anyone help?
tnx
Old 3rd July 2009, 03:56 PM   #7
Netlist is offline Netlist  Belgium
Netlist's Avatar
You will want a full service manual for good troubleshooting and I don't see it at vinylengine.
I have a paper copy and I'll see what I can do.
Meanwhile, check the board for bad solderings, especially around transistor Q201.
Old 3rd July 2009, 04:05 PM   #8
there is no bad solderings
Old 3rd July 2009, 04:07 PM   #9
Netlist's Avatar
Alright, are you equipped with adequate service tools like a good DMM and a scope?
I ask because the troubleshooting needs at least these instruments.
/Hugo
Old 3rd July 2009, 04:25 PM   #10
Netlist's Avatar
Here's something useful if you are skilled enough.
Otherwise, I would advice to take it to a good service tech.
/Hugo
Technics 1210 Mk5 Problem qwaszx Analogue Source 3 31st October 2007 06:19 AM
Technics 1210 problem matt J Analogue Source 5 19th April 2007 10:25 PM
Technics 1210 problems! djruntime Analogue Source 11 13th September 2006 06:01 PM
technics 1210 M5G: Has this been rebuilt? sikniks Analogue Source 3 1st August 2006 03:04 AM
technics 1210 problem tdiman Analogue Source 3 25th November 2005 04:50 PM
Page generated in 0.10964 seconds (78.36% PHP - 21.64% MySQL) with 11 queries
