Old 3rd July 2009, 03:25 PM   #11
Netlist is offline Netlist  Belgium
Netlist's Avatar
Old 3rd July 2009, 03:26 PM   #12
Netlist's Avatar
Old 3rd July 2009, 03:47 PM   #13
sw3Ex is offline sw3Ex  Croatia
tnx all IC was changed and tested before, everything is ok with them. i have put them on another mk2, and they are working without any problems :S
Old 3rd July 2009, 03:50 PM   #14
Netlist's Avatar
Does the behavior change when you unplug the fader?
Old 3rd July 2009, 03:56 PM   #15
if i unplug the pitch, the behavior is still same. i have changed the motor, behavior is still same.
but the motor from defected technics starts a little bit slower in a good technics. i think it is little bit burned up
Old 3rd July 2009, 04:03 PM   #16
Netlist's Avatar
No, I think the bearing needs some oil.
If you have a good working unit, why don't you try changing the complete PCB and see what you get?
(I unsolder the pins where the transformer wires are attached.)
Old 3rd July 2009, 04:29 PM   #17
i have changed PCB, same problem still some ideas more maybe?
Old 3rd July 2009, 04:48 PM   #18
Netlist's Avatar
There's the power supply, the main PCB, the motor, the fader and the technician...
Old 3rd July 2009, 04:48 PM   #19
the tehnician didnt know where is problem
Technics 1210 Mk5 Problem qwaszx Analogue Source 3 31st October 2007 05:19 AM
Technics 1210 problem matt J Analogue Source 5 19th April 2007 09:25 PM
Technics 1210 problems! djruntime Analogue Source 11 13th September 2006 05:01 PM
technics 1210 M5G: Has this been rebuilt? sikniks Analogue Source 3 1st August 2006 02:04 AM
technics 1210 problem tdiman Analogue Source 3 25th November 2005 03:50 PM
Page generated in 0.10165 seconds (77.21% PHP - 22.79% MySQL) with 11 queries
