| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#982 |
diyAudio Chief Moderator
8.5mA is very good for the Rsource resistors I recommended.
#983 | |
The current is governed by the CCS. Must be 212mA with Vbe/3R3. Can you measure it at the input? |
#984 |
My local supplyer do not stock 550`s nor 560`s.
I have bc549b and bc559b,will they do the job in the shunt? I´m almost done with the wireing,just have to fix the ac inlet and switch and maybe a fuse.
#985 | |
The 549 seems to have a bit lower maximum allowed voltage, 30V, instead of 50V for the BC550. But in this circuit, I don't think you'll get more than 25V across the transistor anyway. |
#986 | |
Later. |
#987 | |
#988 |
Hi Salas
Yesterday I noticed the 560r (554r real) resistor I was using to load the shunt during testing, was really hot so I decided to measure the current flowing. By my calculations: (I=V/R) ;R load = 554 ohms; Vout = 28.2 Volts, the current should be 50.9 mA. In reality I am reading 78.2mA I decided to change the loading resistor to a 1kr (988r real) and now the current reading is 43.3 mA Am I missing something ? Is there a problem with my DMM ? Regards Ricardo
RC |
#989 |
Did you measure with your DMM set for current in series with the dummy load? There it is just I=V/R. We use 500R so to have about 50mA, which is comparable with 2 phono channels of your version, so to judge the reliability with given sink on the shunt Mosfet, stability over time, and correct voltage output. Maybe the dummy resistor isn't so big for the heat it develops so its resistance plays way off?. Or the DMM does tricks?. I usually use 3 times the Wattage of actual dissipation on resistors. So I would use a 5W dummy in your case. If it has 28.2V across, and it is 500R and holding, there is no way than running anything different than 56.4mA through it. But being able to measure correctly as expected or not what the dummy consumes, is irrelevant to the PSU. As long as the dummy sinks some current and nothing oscillates, when the voltage is stable at nominal, all is working well.
#990 |
I measured with the DMM set for mA, in series with the load resistor.Maybe my DMM is not correctly set.
Tonight I will try and measure with an analog MM. The shunt delivers 28.2v steady with any of the loads (and even without any load). Ricardo
RC |
| Page generated in 0.15806 seconds (66.26% PHP - 33.74% MySQL) with 11 queries |
