Simplistic NJFET RIAA - Page 988 - diyAudio
Old 15th June 2013, 09:27 AM   #9871
AndrewT is online now AndrewT  Scotland
Originally Posted by Jallhalla View Post
......................The signal cable Im using in the f5 has two internal wires plus a shield. The shield is usually connected floating in the "source" and not connected at the end. How should I do this in the f5? Only connected to signal ground in the amp and not on the chassis rca?
Or should I just use a standard coaxial cable?
Use the shielded twisted pair.
The cores carry the Signal Flow and Return.
The Shield gets connected to the Source Chassis and connected via a small ceramic cap (smd1206) to the Receiver Chassis.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th June 2013, 10:26 AM   #9872
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by merlin el mago View Post
Ricardo I bought mine Vishay 1280G to Michael Percy Audio USA
Thank you Merlin.
Anyway you might as well try these WW pots, I would really appreciate your input
RC
Old 16th June 2013, 06:02 AM   #9873
Originally Posted by Salas View Post
Its deeper blue in real life, something like blue-black-green. Because the board is thick. When some direct light hits, it opens up in tone. The sinks will be designated as the 1.5inch height model to match the towering electrolytics and be heftier. Black gives more contrast. Blue blends nice. If it was PRP resistors and black connectors it would suit black better. Your call guys, just vote.
green
Old 24th June 2013, 09:56 PM   #9874
dimkasta's Avatar
WOW Niko... amazing....!!!!
If you need any help fast, feel free to whip my @$$...
You have my soldering iron, my scope and my bow...
Second harmonic and wine for everyone...
Old 25th June 2013, 09:22 AM   #9875
merlin el mago's Avatar
Originally Posted by RCruz View Post
Thank you Merlin.
Ricardo is the best trimmer available.....
Old 25th June 2013, 12:06 PM   #9876
nhinstruments
RCruz's Avatar
What do you mean, did you try these WW ?
RC
Old 25th June 2013, 01:47 PM   #9877
Yes
Old 25th June 2013, 01:56 PM   #9878
nhinstruments
RCruz's Avatar
What is your subjective opinion, comparing these WW to the Vishay bulk metal you got from Michael ?
RC
Old 25th June 2013, 04:30 PM   #9879
Sorry Ricardo I used only Vishay 1280G trimmer but the data sheet of these WW isn't bad 20ppm 5% and the price is fair please let us know how works.
Old 30th June 2013, 03:58 AM   #9880
ide2003 is offline ide2003  Indonesia
hi all,
finally after +1 year MC gain stage with Azur 540 I've made ptp Salas RIAA, MM version with buffer. Still not in the box and no listening yet, I think the hum is bit high, managed to get it down a bit. measured output with Visual Analyzer. Supply is Salas shunt reg with 5 leds.
Is this quite normal? what is the average noise w/o input signal, got it 23mV rms with DVM. Advice to get hum down is appreciated, looking forward to listen and many thanks to Salas
Copyright 1999-2017 diyAudio
