Simplistic NJFET RIAA - Page 978 - diyAudio
Old 15th May 2013, 02:56 PM   #9771
buzzforb's Avatar
Originally Posted by Salas View Post
For what? To make a super linear buffer for this open loop some second harmonic climbing with level phono? The B1 type buffer it has suits it better IMO. Its like adding precision optics to a slingshot otherwise.
No argument from me. I knew RCruz had been talking of Calvin buffer with Joachim, so i was unsure of how far he had taken it. Other than possibly adding the B1 on the output, like Rush, I see no reason to change anything. Sounds to good.
Your boards are actually soldered. I haev to get a couple 33r resistors to make 43R on output stage Rs and then they will be headed your way.
...Shape the sound , Man!
Old 15th May 2013, 03:03 PM   #9772
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There is a b1 already in the folded just before the output cap when Rush's has a DCb1 for using a smaller cap. Simple repositioning.
Thanx! Will be waiting.
Old 15th May 2013, 03:11 PM   #9773
buzzforb's Avatar
B1, DCB1. I am so confused
Is shipping within Europe cheaper than to continental US. If so I might send RCruz his TX2575 resistors through yuo if it will save on postage and you dont mind.
Old 15th May 2013, 03:14 PM   #9774
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I am interested in buffers, but Calvin's works with simetrical psu... not applicable anyway.
And in this case I was only reporting about changes made in the shunt.
RC
Old 15th May 2013, 03:22 PM   #9775
Rush is offline Rush  United States
B1 is cap coupled, DCB1 is direct coupled.
Rush
Old 15th May 2013, 03:37 PM   #9776
Salas's Avatar
They both use a coupling cap in this case, its only you save on a bigger cap when adding a further supply. If the negative polarity supply is already there in a combo pre, then why not.
Old 15th May 2013, 04:01 PM   #9777
buzzforb's Avatar
I know. I have built both, just forgot the DC part in my writing above. I have learned a few things.
Old 15th May 2013, 06:45 PM   #9778
massimo is offline massimo  Italy
I like Rush's idea very much....
Ricardo, now it's up to you: make a (no-longer-simplistic) folded cascode RIAA front end + DCB1 o/p stage with six (!) SSLV V.1.2R
Old 15th May 2013, 07:36 PM   #9779
nhinstruments
RCruz's Avatar
Allready have a dcb1 with two v12r
So maybe I could power the folded with four (instead of two) v12r ad get to the inline six.
I like the inline six sound but even more the v12... with smaller pistons... they really scream.
RC
Old 15th May 2013, 07:44 PM   #9780
You can use just 4 V1.2R.... if you already have a super DCB1, you can replace the last stage of your folded, listen and report to us poor souls
Copyright 1999-2017 diyAudio
