Simplistic NJFET RIAA
Old 4th April 2013, 09:21 PM   #9611
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That is where BJTs excel but Fets like the 389 near a lot.
Old 4th April 2013, 09:24 PM   #9612
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
You just convinced me... must buy some 389 soon.
RC
Old 4th April 2013, 09:26 PM   #9613
Salas's Avatar
1x 389 input folded simplistic gave me -100dB 1/F @ 20Hz. Same as with the Paradise.
*2x 389BL would be more fair since the gains of the two circuits would be nearer.
Old 4th April 2013, 09:36 PM   #9614
nhinstruments
RCruz's Avatar
So that is wha i need now.... I felt the 4 x k170 lacked bass grip and is noisier than the 2 x k170 build.
Inittially I wondered if that noise came from the 12ohm Rs used... I was now recalculating the folded ccs resistor to lower these Rs to 3.9ohm... but now I know better... where can I get some good 389 ... ampslab ?
RC
Old 4th April 2013, 09:43 PM   #9615
Salas's Avatar
Yes, 2SK369BL actually, 389 is a K170 extinct double. My typo.
Old 4th April 2013, 09:46 PM   #9616
Salas's Avatar
Its you neared 65dB gain with not the best type for 1/F noise.
Old 4th April 2013, 09:52 PM   #9617
nhinstruments
RCruz's Avatar
Would you care to share your best 369 source ?
RC
Old 4th April 2013, 10:07 PM   #9618
Salas's Avatar
I don't have any best source. I had 20-30pcs that I got from Ebay once. Cowboy legged ammo tape ones that proved OK.
Old 8th April 2013, 09:02 AM   #9619
massimo is offline massimo  Italy
Just finished k117gr mod on V12r vref.... much faster catch up indeed....
Ricardo, which Idss did you chose for the K117 in this position?
or
Salas, which is the reccomendend Idss for the K117?
Thank you both!
Old 8th April 2013, 09:20 AM   #9620
nhinstruments
RCruz's Avatar
I am using 30kr for vref so I need around 1mA to get 35Vout.
I chose a K117GR with 3.6mA Idss... the trimmer on the gate reduces this value to the correct Id.
RC
Simplistic NJFET RIAAHide this!Advertise here!
