Old 12th February 2013, 11:32 AM   #9281
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by Jallhalla View Post
What are the voltage and current demands for the folded simplistic?
I need two bibīs to be one of the cool guys, right? And they are both positive?
Thanks!
You can start with just one BiB set for 35V ... I suggest a minimum 300mA current.
RC
Old 12th February 2013, 11:37 AM   #9282
RCruz's Avatar
Hi Salas
A learning tech question for you.
Imagine I would like to lower input noise and use 4 x k170 there.
This would double Id current so I would need to increase Vdd to around 60V in order to have enough curren over R4 right ?
This is only a suposition, but using the same R13 (1500r) I would also increase gain to around 47dB right ?
RC
Old 12th February 2013, 01:31 PM   #9283
merlin el mago's Avatar
Originally Posted by buzzforb View Post
Oooops I didn't see thanks.
Old 12th February 2013, 02:21 PM   #9284
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Thanks!
The demands are monopole +35V @ 30-35mA per channel. We usually set the SSLV regulator much higher for it to work its MOSFETS better. Usually at 150-300mA CCS per channel depending on how much sinking you are prepared to use.
Old 12th February 2013, 02:25 PM   #9285
Salas's Avatar
Originally Posted by RCruz View Post
Hi Salas
To increase the current you don't need to increase the voltage also. Its a matter of redesigning for proper current biases around the input stage. Buzz uses 2XK170BL @ ~60dB gain with 0.5mV cartridge and he is reporting OK for noise though. Are you going for LMC? There is the 2X369BL 63dB example there already that Merlin has in mind.
Old 12th February 2013, 02:29 PM   #9286
massimo is offline massimo  Italy
Not only
Old 12th February 2013, 03:07 PM   #9287
RCruz's Avatar
No, I am just trying to understand the 1st stage biasing.
I found your post here: Simplistic NJFET RIAA
Just do not know how you determined the 12r for k170 Rs
RC
Old 12th February 2013, 03:44 PM   #9288
Salas's Avatar
4 Rs in parallel amount to 1/4 the value, its just we use one each for better current sharing, auto matching by local feedback in other words. So we get a total current in a single virtual "super transconductance'" JFET device with lower noise, more gain, more gate capacitance. Then the CCS resistor (1K in that example) steals that current from the PSU node just shy of what we need left for the PNP cascoding BJT to run through its resistive load folded to ground (2K2) for centering it voltage wise so we get a symmetrically clipping sinewave at max input drive.
Old 12th February 2013, 06:49 PM   #9289
RCruz's Avatar
So if you used only one common Rs for the four k170, it would have to be 3r to generate the same Vgs right ?
Now I did not think of the 1k resistor as a CCS.... that explains a lot. That resistor must be correctly dimensioned to let go only the right amount of current so if it runs on the fets and also on the folded load resistor.
If we decrease the CCS resistor, more current will flow and as the current through the fets is fixed by Rs, there is more current through the folded load resistor and so more Vdrop there. That is how the trimmer works
Thank you again for your cristal clear explanation.
RC
Old 12th February 2013, 06:57 PM   #9290
RCruz's Avatar
Now in the double K369 schematic you used the same 2r2 as in the single K369 schematic (Not 4r4).... The difference in this case is in the CCS resistor that is smaller (1k2 instead of 2k2)
So your choice of Rs does not follow a strict trend... It must come from your simulation and experience.
RC
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright Đ1999-2013 diyAudio
