Simplistic NJFET RIAA - Page 923 - diyAudio
Old 2nd February 2013, 03:57 PM   #9221
Rush is offline Rush  United States
Originally Posted by massimo View Post
Buzz, check item 261150895343 on ebay. Those 0.047uF FT-2 teflon caps are quite compact (31 mm long, 20 mm dia) compared to the usual ones.
"Silver plated steel leads."
Steel is usually a bad thing to conduct audio.
You may want to open them up and repackage them with epoxied ends and better wire leads.
There is a a thread about doing something like this somewhere around here.
Supposed to help and reduce the size.
I have a few of the larger ones and will eventually take one apart.
Rush
Old 2nd February 2013, 06:25 PM   #9222
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by nicoch58 View Post
Ciao Ricardo , more info on PHY-HP ? you like fullrange ?
yes, I like full range... these index can even output high frequencies like if they had a tweeter.... Very good
RC
Old 2nd February 2013, 06:45 PM   #9223
Are you sure that aren't the coax models ?? at 10k drop like a stone, no fullrange, never see ones without is dedicate tw.
Old 2nd February 2013, 09:59 PM   #9224
nhinstruments
RCruz's Avatar
No coax.
This one; h30lb15sag
very directional... can play really loud... subtle detailed highs... loads of slam and good low end also.... Indeed special. The open bafles are uge.
RC
Old 2nd February 2013, 10:01 PM   #9225
nhinstruments
RCruz's Avatar
Rush
Did not know about the steel ends... Anyway they sound splendid.
looking forward to your cirurgical experiments.
RC
Old 2nd February 2013, 10:38 PM   #9226
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Silver plated ends nonetheless.
Old 2nd February 2013, 11:01 PM   #9227
nhinstruments
RCruz's Avatar
Yes.... And heavy gauge silver plating.... It even oxidates so bad I always need to polish the ends before soldering.... anyway, the results are splendid
RC
Old 2nd February 2013, 11:08 PM   #9228
buzzforb's Avatar
polish them and spary them with varnish or polyeurathane.
...Shape the sound , Man!
Old 2nd February 2013, 11:22 PM   #9229
nhinstruments
RCruz's Avatar
varnish I use... after soldering that is
RC
Old 8th February 2013, 11:41 AM   #9230
merlin el mago's Avatar
Could I use 2SK246BL in place of BF245A?
Copyright 1999-2017 diyAudio
