| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#9171 | |
diyAudio Chief Moderator
P.S. Having two positions already its easy to check one or the other config. |
#9172 |
#9173 |
Thanks for the comments Salas. Degeneration is an option, but i have discivered i like as little as possiblle. Have you tried with none?
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#9174 |
I had double and triple matched 369s without any Rs and they had instability tendencies due to capacitance and gain. Small Rs tamed them. Lends some more linearity also. Although the swings in first stage aren't anything that demanding.
#9175 |
I am going to be getting some TX2575 resistors for the 47K signal path spot as well as some 220R for the DCB1. Anyone interested, PM me Sorry Salas, not trying to turn this into buying thread, just thought RCruz and others might like a shot.
#9176 |
Salas,
redesigining everything and working on the PSU. I am going to have the Toroid in a seperate case, with shielded umbilical bringing the secondary voltage into the main case. I am unsure of how to ground the main case to earth. I will bring earth in the umbilical so the case can be grounded. Just wandering if I just run a wire from the prereg ground to earth ground, sperated by dual diodes. Any suggestions on wire up for quiet ground?
#9177 |
No don't run AC umbilical, run DC only to the phono box to achieve best results. Move the bridge diodes in the Tx box and connect to the filter cap remotely as it will be left alone on the reg board.
#9178 |
Connect PSU ground and reg ground, and reserve one cable in the umbilical to connect chassis to chassis.
#9179 |
Thanks.
#9180 |
I messd around with RCruz calcultor, and from memeory, it does very good job approximating the values.
