Simplistic NJFET RIAA
Old 24th January 2013, 03:31 PM   #9141
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Salas,
I have my student hat on and have a question. What makes one version folded, and the other not.
...Shape the sound , Man!
Old 24th January 2013, 04:32 PM   #9142
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The cascode transistor folding to a ground referenced load.
Old 26th January 2013, 01:45 PM   #9143
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi buzz.
The folded cascode provides higher output swing tan the telescopic at the expense of power dissipation.
RC
Old 26th January 2013, 01:52 PM   #9144
Salas's Avatar
They give advantage in opamps towards applications where the Vs can be limited in the system rail. Low dissipation and consumption goals in high density designs.
Old 26th January 2013, 03:16 PM   #9145
buzzforb's Avatar
Salas,
Rigol 1052 or 1102
Old 26th January 2013, 03:31 PM   #9146
buzzforb's Avatar
Here is the quick and dirty, with both SSLV's up and running.
Old 26th January 2013, 03:46 PM   #9147
Salas's Avatar
Originally Posted by buzzforb View Post
Salas,
Rigol 1052 or 1102
They are the same machine. 50MHZ is plenty for audio projects. They just bias a varicap in the analogue front end differently via firmware and slap a different model label. Their fan can be a nuisance. That is if you breadboard or repair for long and you need concentration. Changing it voids the warranty.
Old 26th January 2013, 03:47 PM   #9148
Salas's Avatar
Try it then to see about hum and get a taste.
Old 26th January 2013, 04:05 PM   #9149
buzzforb's Avatar
Both second stages are at 10V+ with 50r degeneration. Allowed me to drop B+ down, unless you think I need more headroom on second stage.
Old 26th January 2013, 04:30 PM   #9150
Salas's Avatar
Its in spec.
Simplistic NJFET RIAAHide this!Advertise here!
