Simplistic NJFET RIAA
Old 20th January 2013, 08:06 PM   #9111
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Salas
Sorry fo the out of scope question but just for learning purposes,.... in my most recent build, If I used only one common Rs for both k170 in the input, what value should I choose ?
I am using one 3.9 per leg... should I need to use only one 2 x3.9r = 7.8r ?
RC
Old 20th January 2013, 08:11 PM   #9112
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No, to the contrary, halve the original discrete value.
Old 20th January 2013, 08:18 PM   #9113
nhinstruments
RCruz's Avatar
I see I have a long way before me.....
Would you please give me a hint on how to calc Rs and Rd for a circuit using two fets ?
RC
Old 20th January 2013, 08:41 PM   #9114
Salas's Avatar
If they are exactly matched then no one will current hog if with a common Rs. Since you double the current flow you need half the value to maintain the same local feedback (degeneration). Other than when using expensive boutique resistors and need economize there is no advantage VS one Rs per JFet which leaves slack for not that matched semis also. Rd? You mean the Jfets current sourcing resistor? That one derives from the total current drawn by the Jfets plus what you need flow through the common base cascoding BJT to have a range for TP1/TP2 centering. In conjunction with B+. That is why we use a trimmer locally to vary B+ for that CCS resistor. Its a balancing act. You solve against bias currents and B+.
Old 20th January 2013, 09:05 PM   #9115
nhinstruments
RCruz's Avatar
Now I see...
To keep the same Vgs at double current we need half the Rs.
As for the rest... digest will be done tomorow
RC
Old 20th January 2013, 09:08 PM   #9116
Salas's Avatar
...Buzz is quiet...Maybe he managed to listen without problems? Hmm, we will know sooner or later.
Old 20th January 2013, 11:50 PM   #9117
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Couldnt get it finished in time. Too many other activities took away the afternoon. Will resume tomorrow. It will give me the chance to get the other sslv up and running. Thanks for the help. I now understand the current hogging issue. Stepping away and thinking did me some good. Already got new boards drawn and correct jfets coming, as i do not have enough low idss fets to do one right. It willbe SMD again, with this one using Susumu. Should be good comparison of smd choices. I am going to bed. Long day. Thanks again.
...Shape the sound , Man!
Old 21st January 2013, 09:19 AM   #9118
nhinstruments
RCruz's Avatar
So, using 3,9 for Rs, you use the jfets almost at Idss.
In my case Vgs = 29mV so I have 0.0074 Id on each fet
Double current (0.0149) flows on R13 (1k5) droping 22V
For R4 (2k2) we need 4Vdrop so current is 0.0018 that drops 3V on R13(1k5)
Total drop on R13 is 22+3=25v, so we need Vdd over R13 to be 33v so we have 8v on the bjt emitter.
35Vin-33=2V that must be droped on the trimmer... (0.0149+.0018)=0.0167 over the trimmer so it must be around 120r.
Easy to do on paper.. letīs see if I can compute it.....
RC
Old 21st January 2013, 09:26 AM   #9119
nhinstruments
RCruz's Avatar
As I use LTSpice for sim, and do not have mA k170 (only 11mA) and no BC560c, my sim is no good for this purpose.
RC
Old 21st January 2013, 02:33 PM   #9120
nhinstruments
RCruz's Avatar
Almost done.
Salas, would you please post 1st stage gain in the case using double k170 in the input ?
RC
Simplistic NJFET RIAAHide this!Advertise here!
