Simplistic NJFET RIAA
Old 20th January 2013, 03:12 PM   #9101
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by RCruz View Post
I am not understanding... lowering 1k5 can lower gain, but voltage at collector should rise
We want to maintain spec if possible. What you say is correct about voltage. Problem is we got to sort out Buzz with what he put in there now.
Old 20th January 2013, 03:13 PM   #9102
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Let me see if I can make some. What about Lowering Rs on seond stage as way of bringing up drain voltage, taking it from 43 to 33. THis shouldnt affect RIAA, correct? I guess it would lower gain for second stage. It seems that 8mA onthe money is what is needed for Idss. I can get some from Spencer and reset in new build. Will allow me to correct error and redo some things on the board.
...Shape the sound , Man!
Old 20th January 2013, 03:16 PM   #9103
Salas's Avatar
Originally Posted by buzzforb View Post
Salas,
can i not bring up the second stage drain voltage by lower rs? They did not have 43R in Smd, so i have a 33R and 10R in series.
No, the opposite will happen. How much drain to gnd on second stage and how much Tp2 you can obtain with say 39V B+ after trying the Tp2 trimmer all over?
Old 20th January 2013, 03:31 PM   #9104
buzzforb's Avatar
39V B+, 8.6V on TP1, 4.3V on TP2, 7.8V on second stage drain. I can raise TP2 to above half TP! an increase second stage V.
Old 20th January 2013, 03:50 PM   #9105
Salas's Avatar
TP1 and TP2 relation is good. It should be listenable now. I would prefer 10ish on second stage for headroom. Either by increasing Rs or dropping IDSS in second stage fet selection.
Old 20th January 2013, 04:02 PM   #9106
buzzforb's Avatar
I can put different Fet in and try. Increasing Rs would linearize it some. Which do you think is better choice?
Old 20th January 2013, 04:03 PM   #9107
Salas's Avatar
Increasing Rs. Since you got the extra gm its a linearity bonus. Two birds with one stone.
Old 20th January 2013, 04:06 PM   #9108
buzzforb's Avatar
10 ohms too much? I got another SMD that size.
Old 20th January 2013, 04:24 PM   #9109
Salas's Avatar
Try. At 50+ Ohms total its a good point for THD.
Old 20th January 2013, 04:28 PM   #9110
buzzforb's Avatar
That's a loaded answer if I ever heard one. Will do. Going to listen tonight. Report back.
Simplistic NJFET RIAAHide this!Advertise here!
