Simplistic NJFET RIAA
Old 20th January 2013, 01:28 PM   #9071
samoloko is offline samoloko  Bulgaria
what are you using as a output coupling cap
Old 20th January 2013, 01:30 PM   #9072
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Buzz, you can't get a voltage across the collector if you can't have spare current for its 2K2 load is a suspicion. That can occur if your input Jfets are stronger and drop much over the 1K5 resistive CCS. Try trimming B+ slowly up on the SSLV while watching the collector to ground voltage. See if it will start showing up at a point. So we can have a picture of this assumption.
Old 20th January 2013, 01:33 PM   #9073
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I have a range if 3.5V to 8.75V using the trimmer.
...Shape the sound , Man!
Old 20th January 2013, 01:33 PM   #9074
Salas's Avatar
Originally Posted by RCruz View Post
Hi buzz
Seems you might have trouble with the first stage Voltage setting trimmer.
I once did not get Q2 collector voltage because the trimmer did not go low enough.
That ties with the above. If its drawing more 1st stage 1K5 CCS current than designed even at zero trimmer, its not enough.
Old 20th January 2013, 01:34 PM   #9075
Salas's Avatar
Where is that range? At TP2?
Old 20th January 2013, 01:41 PM   #9076
buzzforb's Avatar
In my drawing the bjt is loaded with 1.5k. The bf845 cs has a 2.2k load. Ill tryt rimming main voltage.
Old 20th January 2013, 01:42 PM   #9077
buzzforb's Avatar
TP1
Old 20th January 2013, 02:01 PM   #9078
Salas's Avatar
1k5 is feeding the fets, 2k2 loads the bjt's collector to ground is the correct thing. TP1 changing means there is variability because there is no constant voltage (Leds+Vbe) provided by the bjt. Watch TP2 with a DMM as long as providing increasing B+ after you make sure the 1k5 and 2k2 resistors are configured as I mentioned.
Old 20th January 2013, 02:03 PM   #9079
Salas's Avatar
BF245's 2k2 and 100uF to ground is an RC filter, not a load.
Old 20th January 2013, 02:10 PM   #9080
buzzforb's Avatar
It is arranged as you say. Ill reportback.
Simplistic NJFET RIAAHide this!Advertise here!
