Simplistic NJFET RIAA - Page 906 - diyAudio
Old 19th January 2013, 10:58 PM   #9051
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes. You should have half the BC560's emitter to ground voltage on its collector to ground after trimming, ~10V across second stage's Jfet drain to ground, for 35V to ground B+. Also the BF245 looks like drawing much. Either isn't an A type (lower IDSS rank) or its a short.
Old 19th January 2013, 11:39 PM   #9052
buzzforb's Avatar
I have bf245b. I have 4ma of current on Jfet gain stage after 43R degeneration. Both channels exactly the same. In terms of general settings and measurement. Is it the bf245b?
...Shape the sound , Man!
Old 19th January 2013, 11:54 PM   #9053
Salas's Avatar
Check its legs in its datasheet, its not like Toshiba pin order in case you did not, also take them down to 5mA with a resistor on their gate to source, feeding the leds from gate. See from there on by measuring again.
Old 20th January 2013, 12:37 AM   #9054
buzzforb's Avatar
Are you saying insert a degeneration resistor into current layout. The led's are just a Vref for the bjt, being fed by bf845 current source, correct.
Old 20th January 2013, 05:26 AM   #9055
Salas's Avatar
Correct. Or use a K117GR if there is no space for a resistor. Only be sure about orientation. If its wrong or type is changed, do the Irish dancer leads with a pliers.
Old 20th January 2013, 08:50 AM   #9056
when you use obbligato premium gold as a coupling which end Is recommended to be In and which out for signal
do you recommend bypass of obbligato premium gold 4.7 uF - If you do which bypass and value - teflon ft-1 ft-2 ft-3
Old 20th January 2013, 09:31 AM   #9057
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I normally use the cap orientated as per its casing lettering.
input -------[Obbligato]-------- output
I would start without any bypass. Let the caps settle and see if you like the sound. I once bypassed one of those with a smaller obbligato (0.47u) with good results.
RC
Old 20th January 2013, 09:33 AM   #9058
nhinstruments
RCruz's Avatar
Hi buzz
Here you have my measurements... appart from output buffer, it is the same as yours.
RC
Old 20th January 2013, 09:36 AM   #9059
thank you for reply
I have listened at least 100 Hrs but still think that Is missing air
Old 20th January 2013, 09:38 AM   #9060
nhinstruments
RCruz's Avatar
thank you for reply
In that case a 100n FT-3 will open it wide.
RC
Copyright 1999-2017 diyAudio
