Simplistic NJFET RIAA
Old 19th January 2013, 09:32 AM   #9031
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
A single warm enough SSLV1.1 is enough to get you 90% there for the folded, for now. If it will be to your liking or not it will show even in a less than all out double mono initial test config. See to have no hum and a tuned Riaa for starters. In about 48 hours it will mellow out a wee bit also after the lytics will almost shape up.
Old 19th January 2013, 09:40 AM   #9032
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
hi buzz
Be aware that R6 is 1M and not 3M3....
RC
Old 19th January 2013, 09:42 AM   #9033
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Replaced Vref with 470uF SilmicII, since its a RIAA. It has been run in for a while, so no worried there. The KG in the PSU are new. Caddock is current setting resistor. This is what i liked in the DCB1. Seemed bigger difference in DCB1 was higher current vs fancier parts, bu tit is hard to resist in DIY.
...Shape the sound , Man!
Old 19th January 2013, 09:44 AM   #9034
buzzforb's Avatar
Originally Posted by RCruz View Post
hi buzz
Yup. Thanks for looking out. VGeorge caught Vref cap mistake. We shall see later today.
Old 19th January 2013, 02:20 PM   #9035
nhinstruments
RCruz's Avatar
I have something just for fun hopping to get good comments:
After building a rig to measure 2SK170BL fet Idss and Vp, I found that Vp and Idss are linearly related so I constructed a table ranging from 6mA to 10.5mA using a linear regression method.
Then I analysed all my builds and designed a calculator enabling to determine Rd, Rs and Gain depending on Idss, Vdd and Vdsq.
If you know and want to use a specific Rd, there is an option too.
Severall methods for calculating Gain are presented.... feel free to pick the one you like most
This calculator is speciic for the Simplistic gain stages and may not be good for other purposes because it is based on factors used here.
You can even use it for the classic cascoded first stage because Rd is much lower than this stage output impedance so this cascode does not give more gain but much more bandwith and miller reduction.
RC
Old 19th January 2013, 02:29 PM   #9036
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Wow, thanks for the great work Ricardo.
Old 19th January 2013, 02:33 PM   #9037
Salas's Avatar
The second stage in the folded measures about 37.5dB gain.
Old 19th January 2013, 02:37 PM   #9038
nhinstruments
RCruz's Avatar
Back to work than.... what about the other functionalities ?
RC
Old 19th January 2013, 02:42 PM   #9039
Salas's Avatar
It looks like a very nice comprehension tool. Congratulations for putting it together. Maybe you got nothing wrong regarding functions and just a little tolerance in the measurements or in actual gm gives it 10% prediction error margin.
Old 19th January 2013, 04:31 PM   #9040
nhinstruments
RCruz's Avatar
Thank you
It was really mented as a tool for experimentation and comprehension... as is it is no substitute for a simulator and I really believe we should always breadboard before building anything.
Anyway, The scale factor of 2 in gain Equations is nominal. According to the National Semiconductor FET Handbook (1977), that factor can range from about 1.1 to 2.5 but is typically near 2, so I can easily adjust it based on your input.
Can you give me some gain figures ?
48dB build 28V output stage Rd 4k7 Vd = 11v and Rs 47r
48dB 28V input stage Rd 3k3 Vd = 14v and Rs 33r
57dB 37V output stage Rd 6k3 Vd = 10v and Rs 27r
I believe these will beenough to find a good compromise for the gain equation.
RC
Simplistic NJFET RIAAHide this!Advertise here!
