Simplistic NJFET RIAA
Old 13th January 2013, 08:17 PM   #9021
zeeuw is offline zeeuw  Netherlands
Before a tube with ecc83 for phone
Cart is a Benz Ebony H, in a Consonance arm on a chinese turntable
For the rest DIY, class T amplifier to broadband 1way speaker on panel
Sounds great, very live and direct
Old 13th January 2013, 08:32 PM   #9022
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
FR speaker on panel is beloved in the Orient. Are you located in Asia by any chance?
Old 13th January 2013, 08:36 PM   #9023
Noo, I'm Dutch
Using a Philips Ad 12202 with a Peerless sub
U'r phono is great,specialy with shunt
Old 13th January 2013, 08:38 PM   #9024
Salas's Avatar
Very nice then, glad you like it. Enjoy.
Old 13th January 2013, 09:53 PM   #9025
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Salas,
tested my sk117gr jfets with 9V and 1kR in the drain and they came in much higer thatn expected. In the 7mA range. I am wondering if it is a function of low Vds. Are these usable by dropping the 6.8K resistor or exchanging for lower value? Calculator suggest that 2.2K can be substituted and I should be OK. I figured 70mA load current since I will be running both channels of one shunt. Just want to make sure before firing up.
...Shape the sound , Man!
Old 14th January 2013, 04:58 AM   #9026
Salas's Avatar
They should be 6.5mA max by Toshiba data. Use 10R for drain resistor Vdrop IDSS evaluation. If they are genuine and really in the higher GR range tier then you can fix that see text area series resistor to the trimmer accordingly.
Old 14th January 2013, 09:13 AM   #9027
buzzforb's Avatar
Ok.thanks.
Old 19th January 2013, 12:45 AM   #9028
buzzforb's Avatar
Didn't really mess with this at all since breaking leg of one 9530 in the SSLV1.1. Ordered some more but did not get here. Went ahead and finished the Salas reg. Current setting resistos is parallel 120 and 15, for 13.3R. Shunt current of around 250mA. Probablly low for 2 channels, but don't really want to push sinks any more. Got 36V across output, loaded with 960R. Will trim to boards when attached. Tomorrow. I am tired and have to work tommorrow morning in the cold. Bla! The "plan" is to listen tomorrow or Sunday.
FYI,
This is the folded version I am building.
Old 19th January 2013, 07:12 AM   #9029
Salas's Avatar
Its not low, just not too hot-rod. Two channels like you linked will suck only 70mA out of a single supply.
Old 19th January 2013, 09:23 AM   #9030
buzzforb's Avatar
Yeah, thats what i was getting at. I liked DCB1 with it HOT!
Simplistic NJFET RIAAHide this!Advertise here!
