Old 12th January 2013, 10:42 AM   #8991
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Thin film the TNPW, not Z foil, yes?
Old 12th January 2013, 10:44 AM   #8992
buzzforb's Avatar
For a full fledged board, it would get more difficult. They have enough variations, that switching is no big deal. Paralleling is easy, by stacking. Vishay makes higher power smd versions that i am using. All very similar performance specs. Of course small signal is where the excel. I did get matched caps. And have some teimmer psoitions that cant be seen as an intentional act. There are two sides to every story....an dboard, in this case.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 12th January 2013, 10:45 AM   #8993
buzzforb's Avatar
Yes, TNPW.
I will post the doc on rrsistor noise. You think the YNPW perform well, wait till you see PBH 3W.
EDIT: I was wrong about the 10ppm. That is for Tyco RN73. I picked 50ppm TNPW becaus eit performed better in noise test.
Old 12th January 2013, 11:11 AM   #8994
Salas's Avatar
Because you got to have some thermal mass to fight temp roller coasting. Anyway they look like a good balance between performance and price.
Old 12th January 2013, 11:26 AM   #8995
buzzforb's Avatar
I think you are exactly correct. A good visual picture og this is the chart with the Caddocks. As you go up in power rating increased thermal mass), the noise level drops. Here it is.
https://dcc.ligo.org/public/0002/T09...rent_noise.pdf
They are on par with Vishay Zfoil. Of course this says nothign about the sound of thin film vs foil.
Old 12th January 2013, 02:50 PM   #8996
buzzforb's Avatar
Little update. Home from basketball practive, so time to start. Not sure the grounding scheme is ideal, but can be tweaked.
Old 12th January 2013, 03:19 PM   #8997
merlin el mago's Avatar
Nice pcb, good lucky.
Old 12th January 2013, 03:21 PM   #8998
Salas's Avatar
You should protect it from oxidization with some chemical in the end?
Old 12th January 2013, 03:24 PM   #8999
buzzforb's Avatar
Layoyt wasnt perfect due to hammonds inability to measure. It will be redone.
Old 13th January 2013, 01:24 PM   #9000
buzzforb's Avatar
Got them mostly finished yesterday. Got to mount the SSLV fets on a sink, which sucks with metal back fets. Need to scrub the main boards with alcohol and then will fire it all up.
Copyright ©1999-2013 diyAudio
