Simplistic NJFET RIAA
Old 12th January 2013, 01:27 AM   #8981
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Going smd, so gotta have it.
...Shape the sound , Man!
Old 12th January 2013, 09:14 AM   #8982
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Cool... loocking forward to the results.
Can you post a boom for the smd parts buzz ?
RC
Old 12th January 2013, 10:08 AM   #8983
buzzforb's Avatar
Will do. Just used smd resistors. For small filter caps, i used Panasonic FM simply because they have great performance numbers on paper. May try smd next time, but wouldnt expect much difference. Caps are Auricap XO, and i also got Obbligato gold on you recommendation, RCruz. Using common mode choke for filtering before mur 860's, which will feed 10mF nichicon KG. That will be prereg for Salas shunt, of course. Hope to listen today with brothers rig, as this one is his.
Old 12th January 2013, 10:09 AM   #8984
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There are some low ppm SMD resistors from Vishay although expensive.
Old 12th January 2013, 10:16 AM   #8985
nhinstruments
RCruz's Avatar
So you are planning to listen to it today !!! You are a fast builder
RC
Old 12th January 2013, 10:26 AM   #8986
buzzforb's Avatar
These are Vishay TNPW. I saw their noise performance in a paper Scott Wurcer posted in Blowtorch thread on resistor current noise. I can post if you like. They are such tight tolerance, matching is no concern, and they have ppm as low as 10, in some cases. Susumu RG, i think, is also excellent candidate. I am doing this becausevi like how Salas sets things up for subjective tweaking and figured this would be a untried version. As far as building goes. I have gotten to where i can slingnit pretty fast, but i am not promising it will work
Old 12th January 2013, 10:30 AM   #8987
Salas's Avatar
Do they sell by piece? If they sell by the 10s or 100s...no good.
Old 12th January 2013, 10:35 AM   #8988
buzzforb's Avatar
Yes. Mouser sells the Vishay individually and Digikey sells the susumu. Salas, you should try Isabellehuette PBH. You can get them from Burkline. They have noise number sthat beat som eof the best resistors in the world. Same price as Coddock MP..
Old 12th January 2013, 10:39 AM   #8989
Salas's Avatar
I see they come only in 50ppm when 0.5W though. How do you manage the 2K2 1W in your plan? Then you can't make experiments for load or bridge resistor between types like with through hole, don't know. Good for getting all in one make kinda thinking. Not that cheap though.
Old 12th January 2013, 10:40 AM   #8990
nhinstruments
RCruz's Avatar
Did you manage to get matched caps for the riaa filter ?
I do not see optional caps positins in your boards for trimming options.... my first simplistic was done with an etched board also and when I started to finetune it, it became a big mess.... had to add holes and p2p connections for the extra components.
RC
Simplistic NJFET RIAAHide this!Advertise here!
