Simplistic NJFET RIAA
Old 11th January 2013, 01:54 PM   #8971
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
2.2V is little. The sense circuit must be tied to the force circuit terminated with a load consuming much less than the CCS circuit provides. It should show Vout at its tips too. Is it configured like that now you measure?
Old 11th January 2013, 02:19 PM   #8972
zeeuw is offline zeeuw  Netherlands
the load is the phono stage
but the BF245 can only take 30v, so maybe broken
Old 11th January 2013, 02:25 PM   #8973
Salas's Avatar
Should only see VGS across it when all is working well. This version has been built successfully many times in this thread, you will surely debug it.
Old 11th January 2013, 02:28 PM   #8974
replaced Q2 (BF245) with 1k, nothing changes
Old 11th January 2013, 02:40 PM   #8975
Salas's Avatar
See about the output Mosfet orientation and/or health then.
Old 11th January 2013, 02:40 PM   #8976
thx for your help, will work on it
Old 11th January 2013, 05:59 PM   #8977
Found it!
I build the shunt as double mono
so I needed to increase R1
I will finish this weekend case
and than listening........
Old 11th January 2013, 08:01 PM   #8978
Salas's Avatar
OK. Post some pics when finished to show us. Good luck.
Old 12th January 2013, 01:26 AM   #8979
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Tomorrow, it begins. Here are the boards and prereg.
...Shape the sound , Man!
Old 12th January 2013, 02:24 AM   #8980
Rush is offline Rush  United States
What boards? Thought this was supposed to be PTP???
Rush
Simplistic NJFET RIAAHide this!Advertise here!
