| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#8901 |
Hi salas and all,
just came across this thread again i´m just curious how the folded simplistic will compeed against my build njfet version. As i have most of the parts in my boxes i´m just thinkingabout the sslv1.1. What version did you exactly recommend at the moment? And yes i have a pair of BiB-boards as well ![]() greetings and all the best for 2013 Ulf |
#8902 |
diyAudio Chief Moderator
It will be better if you got in mind some compatible circa 0.5mV MC cart for it. Its been tested with BiB, so its fine.
#8903 | |
Hi Salas
i think i explained my selves wrong ... Quote:
of BiB Version did you use? (By the way to what current should the BiB set? Greetings and a happy new year ulf |
#8904 |
SSLV1.1, the one that comes in a breakable PCB triplet. Best wishes from here too.
#8905 |
P.S. Current at about 200mA CCS per channel leaves very good spare.
#8906 |
The conversion was a total success. Just finished modding my 48dB 28V reference build with the new folded cascode input, running at 35v.
As for repeatibility so far so good. Ultra low noise, ample gain and sounding even more dynamic than the "Wallis experiment". I did not touch the riaa filter (just adjusted the 47k to suit better the 2k2 folded cascode load) On second stage I use 2k2r feeding the buffer so I get 10v out of second stage and 20v over the buffer. (I had to build a BiB to power a breadboard where I reproduced second stage to find the best resistor combinations) It is sounding really serious right now.... Pics latter ![]() Learning question: How high output can I choose for a cart with this configuration ? What happens If cart output is too high.. clipping ? Why did it not happen with the "normal" simplistic ?
RC |
#8907 |
Ricardo, do you use a pair of SSLV 1.2R even in this project?
I read you are going to build a SSLV 1.1, are you going to compare that shunt reg vs the 1.2R? P.S. 2k2 in lieu of 1.8K (R11) ? P.P.S. Happy new Year! |
#8908 |
massimo if you do 1.2R have near the scope to check oscillation, I did both & I prefer V1.2R vs 1.1
Have a Happy New Year. |
#8909 |
Happy New Year 2U2, Felipe!
Basic instruments such as scope, DMM, oscillator aren't a problem
#8910 |
Good luck.
