Simplistic NJFET RIAA
Old 20th December 2012, 08:32 AM   #8871
atupi is offline atupi  Romania
After moving output cap outside of pcb forget to move also the 1M output resistor. I will do this and check if problems still persist.
I'm using russian K75-10 2.2uf capacitors.
Old 20th December 2012, 09:23 AM   #8872
massimo is offline massimo  Italy
Salas, referring to the latest RIAA folded cascode sch, what's the purpose of R4 2,2kohm?
It's a load for the f.c. itself or whatever?
Thank you!
Old 20th December 2012, 09:24 AM   #8873
RCruz is online now RCruz  Switzerland
nhinstruments
RCruz's Avatar
R4 is the cascode load... it is referenced to gnd... less noise from that part
RC
Old 20th December 2012, 09:48 AM   #8874
nicoch58 is offline nicoch58  Europe
HOORAY for SALAS
What a great work !!
and to all
Old 20th December 2012, 09:49 AM   #8875
Thank you Ricardo. The low value puzzled me a bit. Thus this R is affecting (lowering I guess) the o/p impedance of the front end and the riaa network as well.
Old 20th December 2012, 09:55 AM   #8876
nhinstruments
RCruz's Avatar
yes... this 2k2 affects the riaa strongly.
RC
Old 20th December 2012, 04:20 PM   #8877
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
After reinstalling the resistors check DCmV on those NOS hybrid caps (output side to GND) to see if they could be leaky also or not.
Old 23rd December 2012, 08:47 PM   #8878
Doug R is offline Doug R  United States
OK,
I am winding up things chassis-wise. Here are a couple of teaser photos. I will post some more in a few days.
First learning experience: I had a bolt through the toroid trafo that touched the chassis. (I've never used a toroid before.) Had a 20 volt difference between circuit ground and safety ground. I'll get a nylon bolt.
Dumb question: where can I hook an indicator LED without messing up the circuits? The resistors I have in the raw PS drop less than a volt.
Thanks. More to come.
Doug
Old 23rd December 2012, 09:04 PM   #8879
DARIO1997 is offline DARIO1997  Italy
Hi Salas,
I have already built your RIAA Jfet a year ago.
The project has had an update or is it always the same?
Old 23rd December 2012, 09:14 PM   #8880
Salas's Avatar
Look at post #8723
Simplistic NJFET RIAAHide this!Advertise here!
