Simplistic NJFET RIAA
Old 10th December 2012, 10:32 AM   #8821
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Can the folded cascode be implemented with a 28V PSU ?
RC
Old 10th December 2012, 10:38 AM   #8822
The Space Egg Corp is offline The Space Egg Corp  England
The Space Egg Corp's Avatar
Goldfinger ! 00 Salas.
Obviously 24crt sound !
N I C E !
Thanks... I'll order the proper GR's...eBay seller screw-up !
( Ricardo, the GR's are for the BIB reg....I have 50 2SK170-BL for amp boards x4 )
Top experimenting BTW chaps !
Tally Ho !!!
Si.
PS...Ricardo, dunno if you understood...
...I can make low AND hi Ohms now...2 different resistance-wire types.
Let me know if you would like a set...
...can make & mail.
ie...4x low's & 2x highs...right ? for your build.
Also possible to make 'un-equal-sets for 'gain-matching'.
Can send some resistance wire as well...
...good 60s' stuff ( my Dad's ).
Old 10th December 2012, 11:37 AM   #8823
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
By making R13 1K, R10 5.6K, R11 1.6K in your 2xK170 build. But losing 2-3dB gain AND 5V pk-pk headroom.
Old 10th December 2012, 12:04 PM   #8824
Salas's Avatar
Originally Posted by xiaox2k View Post
thanks!
For what?
Old 10th December 2012, 12:06 PM   #8825
nhinstruments
RCruz's Avatar
Thank you I have a "normal" simplistic, 48dB running at 28V that needs some work than !!!
RC
Old 10th December 2012, 12:08 PM   #8826
Salas's Avatar
You should watch it ain't overloading with a given cart if you will convert it. 28V B+ is rather little.
Old 10th December 2012, 12:19 PM   #8827
nhinstruments
RCruz's Avatar
I am using a 30VAC TX, so I have 42VDC before the shunts.
Maybe I could stretch shunts output to 32V....
RC
Old 10th December 2012, 12:27 PM   #8828
Salas's Avatar
That would take R13 1.2K 1W, R10 6K (12K//12K?), R11 1.5K for 57.4dB and better headroom.
Old 10th December 2012, 12:45 PM   #8829
nhinstruments
RCruz's Avatar
Perfect for a chrstmas present... thank you again Salas
RC
Old 11th December 2012, 08:09 PM   #8830
Hi Peoples
Strange...
...just measured my 47n & 15n Ruskie K72's again today...
...and with same meter, same temp & same desk, leads & cup of coffee next to meter...
...they don't seem to 'drift' as before !
Today, they appear WAY more stable !
( must be thawing-out from Siberian cold-storage ! )
Bit of advice please Gentlemen !
Miller/stray capacitance & RIAA values.
OK...got the 'official figures' 47k, 6.8k, 47n, 15.5n.
I guess some allowance for Miller/stray capacitance has been made here.
Just asking...
...as have been using a typical 'on-line RIAA calculator' ( mh-audio.nl )...
...to see if I can 'slightly tweek' the values to better match & suit the C's & R's I have to use.
On entering...47k I get...6834r, 15.95n & 46.52n
Just playing with the combinations really.
I had always thought to use 'fixed resistors', & adjust using 'small caps'...
...but...
...If I shift the 47k down a tad, to about 45.3k...both my cap values 'sync'...
...which could be good.
Just need a 45.3k resistor, which is no problem, I think.
Question is...
...what amount of Miller/stray capacitance, should I be factoring in to this calc. ?
I am def. a subjectivist with sound...
...perhaps it will need some adjustment later...
...but a good 'calced' value to start with, would be helpfull.
Not trying to change 'massively' from 'official values'...
...just trying to get best parts match etc...
...and possibly avoid buying more caps to try.
Will try a few different ones, I'm sure...
...a good match between the 2 R's & 2 C's, will help.
JFET testing went OK...
...I think a good range to match position/channel from...
...slightly low, on average, for BL's...
...but majority, within the same 'low BL range'.
Good news ! ( I think )
Cheers.
Si.
( actualy turned the iron on today !!!...NOT eBay !!! )
Simplistic NJFET RIAAHide this!Advertise here!
