Simplistic NJFET RIAA - Page 882 - diyAudio
Old 6th December 2012, 09:14 PM   #8811
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Rush View Post
I have a couple of pairs at 11.4, 12 and higher.
So my boat isn't floating either.
Rush
11.4 will do.
Old 10th December 2012, 07:32 AM   #8812
The Space Egg Corp's Avatar
Hi Salas
The JFETS ordered for my regulators have been shipped to me wrongly !!!
They are 2SK117-BL, not the 2SK117-GR you specify.
I am sure I already know the answer to this...but anyway...can I use any of them at all ?
I only ordered 10 as 'a test', will need eventualy 4 regs. I think ( for my friend as well ).
This is what was sent :-
12.26
11.11
11.02
10.98
10.40
9.98
9.75
9.34
9.12
8.97
No worries on the 'never ending parts hunt'...
...we nearly go 'em all.
This could be a bit of a set-back though.
I would rather 'bin' the high-current 2SK117BL's than make a 'dodgey-reg'.
What you think ?
Have got 3 @ about 9mA each.
Cheers.
Si.
Old 10th December 2012, 07:54 AM   #8813
BTW
' Zhoufang 's 2SK170-BL's on ammo-belt are looking more 'consistent'.
Just measuring them all ( 50 ).
They seem to be coming out at between 7-9 average ( mostly ).
Good seller to buy from, I think.
Cheers.
Si.
Old 10th December 2012, 07:57 AM   #8814
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Space
What schematic are you going to use ?
RC
Old 10th December 2012, 08:05 AM   #8815
xiaox2k is offline xiaox2k  Hong Kong
thanks!
Old 10th December 2012, 09:10 AM   #8816
Hi Ricardo
Well...
...unless anyone tells me different...
...the standard PDF 'Simplistic' for Hi-MC ( Denon DL-110 ).
' The V George Experiment' not suitable, too much gain.
I like your parallel JFET variation, ' The Wallace Experiment' ?...
...but too much gain again ? You're using 0.6mV Benz.
Dunno, is it ?
Looks like 'Simplistic-Original' for me, unless any other TOP-SECRET schematics about !
Hope to have full JFET current-list, later.
Cheers.
Si.
BTW Ricardo...
...Have now found 2nd reel of resistance-wire...
...much better for very low Ohms, other stuff was better for 30-45's etc.
The resistors don't actualy NEED winding, they can be just 'nude' I think.
Minimal inductance for sure.
The 30-45's could be 'flat wound'.
Old 10th December 2012, 09:23 AM   #8817
nhinstruments
RCruz's Avatar
Hi Space
"Normal" Simplistic uses k170BL at around 8 ~8.5mA Idss, so no GR specified.
Can you find more k170 so you can choose the correct Idss ones ?
I am using the folded cascode simplistic with a 0.8mV Benz with great success because I have a DCB1 buffer (no gain) and a low gai power amp.
WW would be nice for the 33 ~ 39r
RC
Old 10th December 2012, 09:36 AM   #8818
Salas's Avatar
A friend had weird problems with BL in SSLV1.1 once. Proceed with caution. If yours is gonna work stable on scope, use them.
MM and folded simplistic are difficult to go well, it would take too high a VDS with possible gate leakage problems, pronounced on MM higher Rsource. But take comfort, the SNR with DL110 and HiMC gain scheme in classic simplistic is naturally competitive to folded for MC if not better.
The folded schematic with 2x K170BL I recommended to Ricardo in lieu of K369 is near 60dB in reality, and second option to single K369BL. Very good except still wanting for low mid to bass different silicone wafer doping GR noise VS 369.
Yesterday I finished modding to folded and re installed my ref build that belongs to a friend. Awesome result. He was chuffed.
Old 10th December 2012, 09:42 AM   #8819
nhinstruments
RCruz's Avatar
Yes.. the folded simplistic is really impressive.... now easily surpasses even the bjt build even in the bass. Much more organic
RC
Old 10th December 2012, 09:50 AM   #8820
Salas's Avatar
I had the opportunity to listen to it with about 0.8mV cart like yours yesterday. Only bit more pricey. Goldfinger Statement. There it really comes to full.
Copyright 1999-2017 diyAudio
