Old 4th December 2012, 02:39 PM   #8761
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
P.S. Forgot to mention that the big electrolytics in the pics are Pana FC and the small ones Pana FR.
Old 4th December 2012, 02:50 PM   #8762
massimo is offline massimo  Italy
Does it make sense to "invest" high bucks in Silmic II for C5, C6 & C7?
Old 4th December 2012, 02:56 PM   #8763
Salas's Avatar
Not to play oracle, its up to your own decision to make some tries so to suite the parts tone to your own system regarding your experiences from types you are familiar with. To otherwise say that this open loop design will not respond accordingly it would also be a lie. Cook your food to taste with ingredients you trust, we just tested the recipe....In other words.
Old 4th December 2012, 03:03 PM   #8764
I like greek cusine very much anyway
Old 4th December 2012, 03:12 PM   #8765
buzzforb's Avatar
Originally Posted by RCruz View Post
You can find obbligatos 0.1 and 0.047u here Obbligato capacitors (Cool supplier)
I used those as coupling caps but really prefer FT3..... Anyway Salas posted that small footprint is better so FT3 might not be the perfect solution here.
Since i am using SMD resistors, I will try to keep everything tight. Big caps do tend to get in the way. I will start with small MKP and move up. Do you have a link for an Ft3 in apprporiate value. Checked Ebay and known sites and have not been able to locate them. Looking at old NOS polystyrene as well as newer Multicap version. Hope to have evrything here and assembled before Xmas. Great time to sit back and listen. Thanks for the help.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 4th December 2012, 03:18 PM   #8766
Salas's Avatar
I have had very good food in Italy too, no complains.
Old 4th December 2012, 03:22 PM   #8767
RCruz is offline RCruz  Switzerland
RCruz's Avatar
here you have the ft-3 FT-3 0,1uF 0,1 uF 600V teflon capacitors. Lot of 4/NOS | eBay
RC
Old 4th December 2012, 03:23 PM   #8768
Salas's Avatar
FT3 is very rare to appear in 0.047u. 0.1u is the norm. K72 does, but you might find it a bit pinched, depends on other components synergy. Keep in hand Micas along with polysterenes for the 15n15 trim, they tend to either clean up or smooth out the brilliance range depending on your final tailoring assortment of parts. Very good are the styrene and tin foil, combining best of both worlds.
Old 4th December 2012, 03:41 PM   #8769
RCruz's Avatar
RC
Old 4th December 2012, 03:42 PM   #8770
buzzforb's Avatar
Thanks.
Copyright ©1999-2013 diyAudio
