Simplistic NJFET RIAA
Got it (I think... I’ll have to look closer at your second point). I put a Q3X that measured 4.1mA Idss and could then get above 36Vdc. I reduced it to get 3.5V TP1-TP2. Is the goal to have approximately the same TP1-TP2 voltage?
Other board shunt also fires up fine, but I’ll have to put a higher Idss Q3X in it as well. The only other one I have above 4mA is 5.xmA.
Just an update. Board #2 was acting the same as #1 with a 3.5-ish mA Idss Q3X in it. The highest one I had was 5.56mA, so I put that in. Bad move... I was having a hard time getting the shunt voltage into the RIAA stage below 40V. I replaced it with a 3.87mA... much better. Shunt voltage now easily held at 34.5V, which seems to be the sweet spot for easily obtainable 3.6V TP1-TP2.
I haven't built up the raw PSU yet (this week), and once I decide on a final transformer spec for it, I my replace the shunt pots with precision fixed resistors. We'll see.
Might actually have to get my turntable out of storage and listen to it this weekend 🙂
Good progress. But don't replace the trimmers with fixed resistors because you may need to readjust in the future. When you will box it for instance. The input JFETs in MC mode are sensitive to ambient temperature changes.
Got the raw PSU done and got the Antek AS-0532 2x32V transformer.
With 1 ohm RDLInks in, I am getting 41.2Vdc out (at the last 10K resistors) loaded. No problems getting the shunt output to ~34.5Vdc and stable 3.6V on TP1-TP2 with adjustment range remaining on both pots.
I still haven't tried listening to it yet.
I built the MC step up. Sounds very, very good. But it's very sensitive to placement. It must be a meter away from my big class A amp for best results. But it is not in a metal box yet.
Running off batteries for now. Works as advertised.
Anybody compared this against a transformer SUT?
I compared the Salas Step Up run off of batteries with a 1:16 Shure Mic Transformer I bought for cheap on ebay. MM Stage is Salas folded, Cart is Ortofon Quintet Blue.
I have never used transformers before. And it will take a better transformer than this to beat the jfet step up. The transformer sounded very veiled compared to the jfet step up. I tried different loading on the secondary, always sounded dull in comparison.
