Simplistic NJFET RIAA - Page 867 - diyAudio
Old 28th November 2012, 12:28 PM   #8661
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Also: Capacitor Characteristics and Specifications
Temperature Coefficient, (TC)
The Temperature Coefficient of a capacitor is the maximum change in its capacitance over a specified temperature range. The temperature coefficient of a capacitor is generally expressed linearly as parts per million per degree centigrade (PPM/C), or as a percent change over a particular range of temperatures. Some capacitors are non linear (Class 2 capacitors) and increase their value as the temperature rises giving them a temperature coefficient that is expressed as a positive "P".
Some capacitors decrease their value as the temperature rises giving them a temperature coefficient that is expressed as a negative "N". For example "P100" is +100 ppm/C or "N200", which is -200 ppm/C etc. However, some capacitors do not change their value and remain constant over a certain temperature range, such capacitors have a zero temperature coefficient or "NPO". These types of capacitors such as Mica or Polyester are generally referred to as Class 1 capacitors.
Most capacitors, especially electrolytic's lose their capacitance when they get hot but temperature compensating capacitors are available in the range of at least P1000 through to N5000 (+1000 ppm/C through to -5000 ppm/C). It is also possible to connect a capacitor with a positive temperature coefficient in series or parallel with a capacitor having a negative temperature coefficient the net result being that the two opposite effects will cancel each other out over a certain range of temperatures. Another useful application of temperature coefficient capacitors is to use them to cancel out the effect of temperature on other components within a circuit, such as inductors or resistors etc.
RC
Old 28th November 2012, 12:37 PM   #8662
buzzforb's Avatar
What does Percy charged for matching? I am doing the folded cascade version
...Shape the sound , Man!
Old 28th November 2012, 02:09 PM   #8663
merlin el mago's Avatar
@Rcruz
How do you match capacitors? If do you buy matched, do you know how are matched & the real value?
Old 28th November 2012, 03:36 PM   #8664
nhinstruments
RCruz's Avatar
Please wait for Salas review.... My build is quite different from Salas initial schematics.
You must speak with Michael... it depends.
RC
Old 28th November 2012, 03:40 PM   #8665
nhinstruments
RCruz's Avatar
Originally Posted by merlin el mago View Post
@Rcruz
I always ask for matched capacitors because otherwise there will be great differences between them... but even if they are matched, there are always small differences... so If I need two caps, I always buy 6 or more... Then I do matching myself... I have a calibrated LCR.
Anyway there are only three critical caps per channel in a simplistic so it is not a big deal.
I also match all transistors and resistors.
RC
Old 28th November 2012, 03:44 PM   #8666
With 4 cables Kelvin wiring connection? post a pic, thanks.
Old 28th November 2012, 03:58 PM   #8667
nhinstruments
RCruz's Avatar
IMO, if you use polystyrene or teflon you will not need to worry about cap value drifting because these are the most stable.
For instance, when I am short of T$me, I use regular 2% small polystyrenes to top up the main 47n and 15n caps.
It is quite normal to get a wide variation in a batch of caps... for example, I just bought 20 150p 2% styrenes from reichelt and was able to get some matching pairs 149p // 149p, 151p // 151p, 147p // 147p, so I choose the pairs and use them.
If I use those two 151p I am convinced they are exactly the same and will not drift differently with temp.
Off course, if you do not match them for yourself, you must buy 1% or less.... some russian micas have 0.3% spec !!!
RC
Old 28th November 2012, 04:01 PM   #8668
nhinstruments
RCruz's Avatar
Post #8608
RC
Old 28th November 2012, 04:04 PM   #8669
Ricardo I don't see the calibrated LCR.
Old 28th November 2012, 04:06 PM   #8670
nhinstruments
RCruz's Avatar
Sorry, I did not realize you wanted a pic of the LCR
You can search for this: TENMA 72-8150
I used a bunch of 0.5% caps to calibrate it myself.
Inexpensive but effective... no kelvin thou
RC
Copyright 1999-2017 diyAudio
