Old 22nd November 2012, 06:46 PM   #8581
Doug R is offline Doug R  United States
Success (Alas, Temporary)
OK, hooked things up, and it actually played music. Only listened for a minute or so, then put it back on the bench. I was waving my soldering iron around and heard ZIP and something fried. Dumb!!! I will look at it tomorrow.
Anyway made some measurements across resistors, as shown below. Some differences between channels in a couple places, even though most of the JFETS were pretty well matched, except the LED part and the output buffer.
Do they seem reasonable?
Old 22nd November 2012, 07:13 PM   #8582
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Very reasonable except what you note for current through R10 must be what goes through R6 also more or less. R6 currents are as expected. What happened, some crock slipped?
Old 22nd November 2012, 07:33 PM   #8583
I think my iron touched the Vin alligator clip supplying power to the RIAA board and shorted something. Hard lesson.
When I get it working again I will re-check the currents. I know R10 should equal R6 - I will have to check it again.
Old 22nd November 2012, 07:38 PM   #8584
Salas, I am trying some WIMA FKP4 caps. Do you have any experience with them?
It may have been a poor choice, but I will give them a chance. I have read they need 100 hours to break in.
Old 22nd November 2012, 08:04 PM   #8585
HOORAY!
I went back and reconnected things, and everything lights up and looks OK.
Darn lucky!
Re-checked some voltage drops:
R2 (below Q1) - 2.3 mA
R9 (above Q5) - 6.7 mA
R7 (below Q5) - 7.3 mA
R10 (above Q2) - 4.2 mA
R6 (below Q2) - 4.0 mA
R12 (above Q6) - 7.2 mA
Look OK Salas?
Thanks!
Doug
Old 22nd November 2012, 08:36 PM   #8586
Salas's Avatar
The iron tip is normally grounded...
FKP4...good industrial quality. Nothing extra special.
Your last values table makes sense.
Old 22nd November 2012, 08:54 PM   #8587
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Hi Doug
What are those yellow caps you are using in the riaa filter ? I must say they really look good !
RC
Old 22nd November 2012, 09:57 PM   #8588
Thanks Salas,
RC, they are some "vintage" RelCaps.
I think I will get some more. I just wanted to get something working before ordering a bunch of "audiophile" parts. Right now I have a Multicap and a WIMA for coupling. I will see which I like better. I have some russian k40's, but they are .47 uF. The output caps are Angela tin foil.
Also, fortunately I had some Rikens left over for resistors.
Thanks for your encouragement and help.
I will keep you posted on things as they burn in.
Doug
Old 23rd November 2012, 12:03 AM   #8589
The Space Egg Corp's Avatar
Hi Salas
Still on the parts hunt !
Don't want to use any 'Unauthorised Parts'...
...but...
I found some 'nice' high-stability 1.6megs today.
Should be OK in the 1meg positions ?
Yes ?
Cheers
Si.
P.S. cap-pickers...
...what USSR silver-mica's do people like around here ?
I read the larger ones in the 'metal-cans' are good for bigger values, like 47nF & 15.5nF...
...anyone tried them ?
Old 23rd November 2012, 01:14 AM   #8590
Salas's Avatar
No, use 1Meg.
Copyright ©1999-2013 diyAudio
