Simplistic NJFET RIAA
Old 19th November 2012, 08:05 PM   #8551
Doug R is offline Doug R  United States
OK, so you're saying to lose the PS resistors to get back to about 38 Vin right?
I was initially worried about frying all the sandy things, so I didn't want voltage into the regulator to be too high.
I appreciate your evaluation from a distance. I have been so worried about measuring little things and not seeing the big picture of how much current I was drawing.
Efharistó Salas.
Doug
Old 19th November 2012, 08:09 PM   #8552
One more thing:
I still want 38 Vin with a 60 mA (28 V/0.06 A = 466 ohm) load, right.
How do you put up with idiots like me?
Thanks.
Old 19th November 2012, 08:11 PM   #8553
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Doug
Right. First thing is we have enough Vin and from there we see next. But look on B & C points of thinking while you are at it. (#8548).
Old 19th November 2012, 08:14 PM   #8554
Salas's Avatar
One more thing:
Thanks.
No worries, I do worse all the time myself.
When such reg works its CCS properly, then its output load changes nothing for its input draw. Its a current regulator wall between input and output sorta.
Old 19th November 2012, 08:18 PM   #8555
OK Salas,
Here are the gridstoppers, 'cause to me gridstoppers are for TUBES, not sandy things.
I will move them to be right at the legs, and decouple raw supply with some film caps.
Doug
Old 19th November 2012, 08:42 PM   #8556
Salas's Avatar
Doh before, good now if will be moved smack on gate pin. See them stoppers as sandy bridge without Intel I7 price tag crossing over to heater-less pentodes. That will sweeten this bitter pill somehow.
Old 19th November 2012, 08:49 PM   #8557
Nah, unless they're round and made of glass, they are just three legged fuses to me.
Maybe I'll glue a 45 tube in there to make it look real.
I will post again tomorrow.
Old 19th November 2012, 08:50 PM   #8558
Salas's Avatar
See ya then.
Old 20th November 2012, 01:32 PM   #8559
Good Morning Salas!
Changed the raw PS. Bridge to 4 ohm R --- 100 uF Cap ---- 2H Choke----4700 uF Cap ------ 4 Ohm R ------4700 uF Cap, then to Reg
Initially this raised Vin to Reg up to 30 volts, so I replaced the 10 ohm R1 with 22 ohm to get load down. Vin went up to 47 volts,
Vin = 47 V
Vout = 3.5 V with 500 ohm load on reg and pot set at 1.5 kOhm
V across R1 now 1.8 V (1.8 V/22 Ohm = 82 mA)
V across R4 = 46 V
V across R5 = 0.62 V
Q1 G to S = 3.0 V
Q4 G to S = 3.3 V
Q3 B to E = 0.6 V
Q6 B to E = o.6 V
Q7 B to E = 0.7 V
Q2 G to D = 3.3 V
Q5 G to D = 0.7 V
What's next boss?
Thanks!
Doug
Old 20th November 2012, 01:33 PM   #8560
Also, put CF gate stoppers in nest to Q1 and Q4 and added 0.1 uF cap across input terminals.
Simplistic NJFET RIAAHide this!Advertise here!
