Simplistic NJFET RIAA
Old 19th November 2012, 04:01 PM   #8531
Doug R is offline Doug R  United States
Oops, forgot:
40 V in, 3.5 V out regardless of pot setting.
Old 19th November 2012, 04:05 PM   #8532
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Do you have a spare Q2?
Old 19th November 2012, 04:07 PM   #8533
Salas's Avatar
Are the Leds lit and equally bright now? What are the drops across R4, R5?
Old 19th November 2012, 05:00 PM   #8534
Bksabath is offline Bksabath  United Kingdom
Banned
Sorry off topic cant post picture on PM
Old 19th November 2012, 05:03 PM   #8535
FdW is online now FdW  Netherlands
FdW's Avatar
Originally Posted by Doug R View Post
FdW: I don't understand.
If you remove the white areas of the PCB then air can move freely along the fins of the heat sink and then it will be able cool better.
Old 19th November 2012, 05:29 PM   #8536
I'm back.
I misspoke earlier; It is actually the first LED that looks dimmer. Each drops 1.8-1.9 volts. 5.65 V all together.
R4 shows 20.5 V drop.
R5 shows 0.6 V drop.
Yes I have a spare Q2.
FdW: got it now thanks. that makes sense.
Doug
Old 19th November 2012, 05:31 PM   #8537
Salas's Avatar
Sandro, cheers mate! That hard to find strip will come handy for my TSSA I gather stuff for.
Old 19th November 2012, 05:38 PM   #8538
Salas's Avatar
I'm back.
Doug
Q3 change fixed a number of voltages. Before changing Q2 which is inline loading it and if there is a hit in the error amp they form they usually die together, please look is there completed resistive path from Q5's drain through R7 and trimmer to V+ force AND sense when not tied together at a dummy load? What value is the dummy load again?
Old 19th November 2012, 06:06 PM   #8539
Salas's Avatar
* We want to read some kOhm from Q5 & R7 node to +sense and open circuit to +force when those two wires don't meet each other. Then by turning the trimmer those kOhm to +s should be changing so we know the trimmer is alive.
Old 19th November 2012, 06:40 PM   #8540
AAARRRGGGHHHH
OK. Replaced Q2 before I got your last message Salas.
Vin now reads 21 V instead of 40. (Voltage sag??) Diodes read OK in raw supply.
Anyway, Q1 now gets warm. Q4 still cold.
Pot resistance measures 0 to 4.7 kohm.
Q5/R7 node to Force (+) is big, about 8 megohm or OL.
Q5/R7 node to Sense (+) goes from 3.3 kohm to 8 lohm depending on pot setting.
V drop across R4 is 20.4 V
V drop across R5 is 0.55 V
Vdrop across R7 is 2.7 V
V drop across R1 is 2.2 V
Vin about 21 V
Vout with load (500 ohm) is 3.5 V
Vout with no load is 10.8 V
Q1 G to S = 3.3 V
Q4 G to S = 3.4 V
Q2 G to D = 3.4 V
Q3 B to E = 0.7 V
Q5 G to D = 0.7 V
Q6 B to E = 0.6 V
Q7 B to E = 0.54 V
What next boss?
Simplistic NJFET RIAAHide this!Advertise here!
