Simplistic NJFET RIAA
Old 19th November 2012, 02:17 PM   #8521
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Doug R View Post
Also, Salas, when I hooked up the raw supply to the reg, I connected the raw ground to Force negative. That is right isn't it?
Also, the ground is floating, i.e. not connected to earth, since it is on a breadboard.
Doug
Yes that is right.
Floating GND or not its no make or break condition for getting it running.
Old 19th November 2012, 02:18 PM   #8522
Salas's Avatar
Hey Guys,
I am sure I switched the drain and source when I wired the MOSFETS.
Going to change them now.
Doug
Here is the part where B. Spears enters the scene and sings ooops!
Old 19th November 2012, 02:24 PM   #8523
Doug R is offline Doug R  United States
Update:
After fixing the MOSFET pin wiring,
1. I have voltage in and out. Didn't have good solder joint at Vin turret. Doh!
2. It does't regulate. Vin = Vout (39.5 volts) regardless of pot setting from min to max R.
3. LEDs light up, although the third one is not as bright as the other two.
3. Read some voltages at MOSFET Pins:
For Q1, gate = 34.9 V source and drain = 39.4 V
For Q4 gate and source - 39.4 V, Drain = 0 volts.
My probe slipped, briefly shorting S and D on Q4.
Any suggestions.
Old 19th November 2012, 02:26 PM   #8524
Salas: do you actually listen to Brittany Spears?
Old 19th November 2012, 02:27 PM   #8525
Salas's Avatar
You made much progress though. Now, with DMM in DCV each Mosfet must have ~4V between G & S pin, every BJT must have ~0.6V between B & E pin. Do they?
Old 19th November 2012, 02:29 PM   #8526
Salas's Avatar
I was watching rather than listening when the odd clip was on TV. She had kinda "rounded" musical culture that I tend to appreciate in female artists.
Old 19th November 2012, 02:37 PM   #8527
I guess "musical culture" has a different meaning in Athens. ")
I will go check voltages after I finish my ravioli with pesto. Yum.
Old 19th November 2012, 03:02 PM   #8528
OK, I get
Q1 MOSFET 4.7 V
Q4 MOSFET 3.5 V
Q3 BJT 27.6 V
Q6 BJT 0.63 V
Q7 BJT 0.33 V
Q2 2SK170 0.0
Q5 BF245B 0.0 V
Old 19th November 2012, 03:05 PM   #8529
Salas's Avatar
Q3 must have got a raw deal. Change that for starters.
Old 19th November 2012, 04:00 PM   #8530
OK. Changed Q3
Q1 G to S = 3.3 V
Q4 G to S = 3.5 V
Q3 B to E = 0.7 V
Q6 B to E = 0.6 V
Q7 B to E = 0.7 V
Q5 G to D = 0.7 V
Q2 G to D = 3.5 V
Simplistic NJFET RIAAHide this!Advertise here!
