Simplistic NJFET RIAA
Old 18th November 2012, 09:15 PM   #8511
Doug R is offline Doug R  United States
Default Update
Salas,
Not sure I will get the re-tracing done today, but here are some photos.
Not the prettiest job, I know.
Thank you SO much.
Doug
Old 19th November 2012, 07:46 AM   #8512
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Nice heatsinks
What material did you use to insulate the power mosfets ?
RC
Old 19th November 2012, 10:27 AM   #8513
FdW is offline FdW  Netherlands
FdW's Avatar
Originally Posted by RCruz View Post
Nice heatsinks
I bet it's an insulator
Old 19th November 2012, 10:47 AM   #8514
I used Mica and thermal grease. Is that a no-no?
Doug
Old 19th November 2012, 10:50 AM   #8515
nhinstruments
RCruz's Avatar
Just curious....
It seems ok for me.
RC
Old 19th November 2012, 11:21 AM   #8516
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Doug R View Post
Salas,
Thank you SO much.
Doug
The frontal sinks could be saved for normal circa 200mA CCS I guess. So to simplify. But it must work first so to evaluate temps. If you will do a continuity test between CCS Mosfet tab and sink screw, is there any continuity by mistake maybe? I will try to spy with my little eye the pics for connections also.
Old 19th November 2012, 12:35 PM   #8517
FdW's Avatar
Salas,
Thank you SO much.
Doug
It may be a good idea to remove the circuit board in/below the 4 'ventilation' shafts of the heatsinks, probably just a bit larger (the hole) than the actual shaft size.
Old 19th November 2012, 01:14 PM   #8518
FdW: I don't understand.
Salas: Definitely no continuity to heatsinks.
All:
I will go now and check all the traces.
Do the orientations of the three leggie things look right?
Doug
Old 19th November 2012, 01:17 PM   #8519
Also, Salas, when I hooked up the raw supply to the reg, I connected the raw ground to Force negative. That is right isn't it?
Also, the ground is floating, i.e. not connected to earth, since it is on a breadboard.
Doug
Old 19th November 2012, 01:47 PM   #8520
Hey Guys,
I am sure I switched the drain and source when I wired the MOSFETS.
Going to change them now.
Doug
Simplistic NJFET RIAAHide this!Advertise here!
