Simplistic NJFET RIAA
Old 23rd October 2012, 05:08 PM   #8321
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by massimo View Post
Mediterraneo currency
With Monica Bellucci on the banknotes at last.
Old 24th October 2012, 03:51 PM   #8322
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Now listening to the "Wallis Experiment"....
It worked at first try... Low noise, quite high gain (must be near to 60dB), very good tone (my riaa recipe )
I will let it burn for a while so I can post a serious listening impression.... for now I consider it a success, even with a low quality output cap it is very difficult to point any weaknesses.
RC
Old 24th October 2012, 03:59 PM   #8323
Salas's Avatar
Its conservatively 58dB nominal. You could have hit near 59 or more. Listening with the Benz Ace? Any pic?
Old 24th October 2012, 04:22 PM   #8324
nhinstruments
RCruz's Avatar
Only completed one channel so I am comparing it with paradise with a Denon cart.... that is why I believe I have near 60dB.
I am now finishing the second channel and only after that I will connect it to the Benz ACE and start serious listening.
Pics latter
RC
Old 24th October 2012, 04:26 PM   #8325
Salas's Avatar
So you hooked an HMC for now? The 160?
Old 24th October 2012, 04:50 PM   #8326
nhinstruments
RCruz's Avatar
Yes... one chanel on the "experiment", the other on the paradise.
RC
Old 24th October 2012, 04:51 PM   #8327
nhinstruments
RCruz's Avatar
Some guys know How to post big pictures.. I do not know how...
RC
Old 24th October 2012, 05:24 PM   #8328
nhinstruments
RCruz's Avatar
Look Ioannis here
RC
Old 24th October 2012, 05:47 PM   #8329
select your pic.
crop it to show the area of interest.
Save it @ the resolution your want us to see.
Compress it using an appropriate .png, .pdf, .gif, etc.
Save it to desktop. I find that easier because it is easy to find the pic file when attaching.
Open your reply.
go advanced.
manage attachments.
browse to find your file.
open. Check the file name that has appeared in the box.
upload.
post reply.
I hope I got that right, it came from memory. (sometimes it works, other times it plays tricks).
regards Andrew T.
Old 24th October 2012, 05:55 PM   #8330
post8328
640x430pixel pic,
200403B
jpeg
the compression used has very little effect. try a different file compressions. Compare lots of different compression types. Some work very well and maintain image quality ans some are terrible. Each pic type generally responds better to some compressions than to others. I can never remember which suits, so I do at least three and select the one that has good image and small file size. Then use the same compression for the other similar files that need to be attached.
regards Andrew T.
Simplistic NJFET RIAAHide this!Advertise here!
