Simplistic NJFET RIAA - Page 822 - diyAudio
Old 17th October 2012, 03:35 AM   #8211
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
This phono has built in pre roll-off between stages keep in mind. Its for anti vinyl disc eccentricity, TT VLF rumble and the like.
Old 17th October 2012, 03:38 AM   #8212
Salas's Avatar
Mild subsonic one.
Old 17th October 2012, 03:44 AM   #8213
andyr is offline andyr  Australia
Originally Posted by Rush View Post
You can pick what ever size output cap you have or want and figure the resistor backwards within reason, 1 meg being the highest value resistor.
The roll off frequency should be less than 2 Hz.
Rush
Sure, Rush, I understand:
a) the inverse relation between resistor value and cap value, and
b) the far higher cost of good caps - so it's cheaper to use a 0.1uF cap than a 0.2uF cap!
I was simply wondering if 1Meg was pushing it a bit high!
I am not the master of JFET knowledge, I leave that up to Salas.
So, Salas ... can you advise?
Q1: Is it a problem to use a 1Meg resistor on the Gate of a JFET?
Q2: Would it be better to use 500K?
Thanks a lot,
Andy
Old 17th October 2012, 03:52 AM   #8214
Salas's Avatar
Depends on Jfet type and its gate leakage current spec IGXS-VDS. The way we bias them in the simplistic they won't leak more than 100pA, so no problems with up to one meg. I had cranked them up further even and could not see any sudden rise for noise floor in FFT.
Old 17th October 2012, 05:19 AM   #8215
Thanks, Salas,
JFET is Toshiba 2SK170GR with Idss 5-6.5 ma.
Andy
Old 17th October 2012, 03:03 PM   #8216
johnm is offline johnm  United Kingdom
johnm's Avatar
Originally Posted by kstlfido View Post
Hi John- Please feel free to emulate away!
How does it sound? Great! I only have a Mitsubishi Integra preamp to compare it to. My Salas RIAA build has more dynamics and life. Very happy with it's sound. Of course there are many variables and subjectivity. I'm also using a lab supply to power the shunts as I've been too distracted/busy to build a transformer/CLC power supply.
It doesn't have quite as much gain as the Integra but plenty loud enough. Possibly the latest ideas on this thread will address that. Still good to go. I hope I can get into in a box for Burning Amp in October!
-Kent
Sorry for some reason I missed seeing your reply Kent. Very encouraging to hear about your results. I'm still getting the parts together, but hope to start building next month sometime
Glad it's being enjoyed - does seem to be a universally well-liked and highly praised design. I'm really looking forward to giving it a whirl.
John.
Old 17th October 2012, 06:02 PM   #8217
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Default hmmmmm
That pic is from the mate's line pre. I put single supply b1 in the ones we are going to check out already, a couple of 1uF simple supreme caps I got, the pot to the 6v6 buffer is 50k, no need I go symmetric supply and dcb1.
Do I understand it right? The line pre is a combination of mezmerize switching control, with some part of b1 and a 6v6 buffer?
Old 17th October 2012, 06:08 PM   #8218
Salas's Avatar
No, the second line comment is about the experimental phono. The little line amp will be with some gain, simple symmetric Fet John Curl style cheap to make solution. I had given him a B1 from mid summer now not to be without music, but he has to have some gain, his ARC amp needs that even from a CDP as source.
Old 17th October 2012, 06:34 PM   #8219
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Now with a much better matched k170 at 8mA idss, I get 12v sharp on the output of the cascode.
Using 1k4 to power the buffer (also with 8mA fets) I get 23.7v for Vd on the top fet....
Wondefull... Allready have one board populated... soon to be news about experimental wallis simplistic
RC
Old 17th October 2012, 06:38 PM   #8220
Siberia's Avatar
Thanks. Sometimes I miss a line switch on DCB1.
Copyright 1999-2017 diyAudio
