| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#811 |
diyAudio Chief Moderator
IRFP9240 can handle 12A 200V. I have designed a shunt for a friend at 13V 3A, he will use it soon for his T-Amp, both channels. Nice loons we are, a cool running digital amp, with a hot linear shunt.
As you see RCruz, the cost for my shunt is low, and is nice to make something DIY. Keep it to directly compare SPower on the JFET phono, and let us know. If SPower proves better, we converge to it. |
#812 | |
As for disposing the etchant. You can re-use it quite a few times. When it's no longer good, you should search in your local city about disposing of hazardous chemicals. |
#813 |
That's the same process I use! Watch out for Stainless Steel sinks though, as the etchant with "etch" that too!
Lee. |
#814 | |
For Ken's layout it probably is very easy to separate power and signal ground; it seems that only Vin, the diode, and the three electrolythics are connected to power ground. |
#815 | |
There was no smell, I did mix the ferric chloride cristals with warm water to make the etchant but did not heat it afterwards. No smell but a funny feeling in the respiratory system... my wife kept coughing... Maybe I should have done it in an open space and not inside the house. Nevertheless there was no harm...! Ricardo
RC |
#816 |
Hi Salas
I am already populating the shunt pcb. As I collected all the parts locally, I am having some trouble with the quality of the resistors and leds. Refering to your last post 728 http://www.diyaudio.com/forums/showt...56#post1722356 about the +28V with leds, I would like to know if there is some flexibility about the values: R1 (6.8R 1W) - I have got 7.4R 1W.. can it be used ? Leds - Green "normal ogive type" .. Are these determinant in the output voltage ? If so, how can I check the leds dropout voltage ? C1 C2 (100uF 10v // 35v) can I use other values ? 120u ? are these determinat in the output voltage ? Any of those needs to be low noise / low esr ? Looking good.... Ricardo
RC |
#818 | |
http://www.reichelt.de/?;ACTION=3;LA...084e4b2183c2a1 All FC with nice price here http://www.reichelt.de/index.html?;A...084e4b2183c2a1 Carsten |
#819 | |
#820 | |
Yes you can use other bigger values for those local noise filter capacitors. Better be low ESR, but nothing really fancy. No they don't determine any voltages, the Zener and the BJT Vbe does that. Just don't change the uF value of Cout if you can (I have determined its transient termination best value), and use there the best you can. More capacitor Voltage value than 35V in your shunt, no problem. |
