Old 15th October 2012, 07:19 PM   #8181
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
What brand are your BF FETS, and what type DMM you use?
Old 15th October 2012, 07:36 PM   #8182
RCruz is offline RCruz  Switzerland
RCruz's Avatar
The fets came from reichelt they have a Fbb42 printed... Fairchild ?... Measured 17mA idss....I am using a TENMA 72-7930
RC
Old 15th October 2012, 07:43 PM   #8183
RCruz's Avatar
Originally Posted by Rush View Post
OK, received the caps, Mundorf 0.1 uF Silver and oil.
Took out the direct coupled JFET, added a 0.1 uF cap with 1 meg to ground on the RIAA board. Then ran to an out board DCB1 sub board and pulled power and ground from the Mezmerize B1 Buffer. I am not fretting about large caps anymore and no hum issues, sounds fantastic.
This is a must do, actually the Mezmerize B1 Buffer board could have double set of DCB1s before and after the volume as I have essentially done and it wouldn't hurt. Four JFETs are a lot cheaper than high quality, large value, coupling caps.
Thank you Salas,
Wonderful stuff!
Rush
Hi Rush
Can you post a schematic of what you have now.... very interested I am.
RC
Old 15th October 2012, 07:47 PM   #8184
Salas's Avatar
Its 0.8% +1 count for DC mA which is decent. One 0.5% +10 count meter I got was still showing shy by 0.2mA to my best 0.15% meter for BL. So it must be IDSS and meters.
If you see a tiny f somewhere not in in part number line on your 245's face its FAIRCHILD.
Old 15th October 2012, 08:09 PM   #8185
Rush is offline Rush  United States
Default DCB1 added to output
Hi Rush
Yes, here is an earlier schematic that shows the output of the cap (0.1 uF) and 1 meg to ground (just the output is the part I used, not the RIAA from this early one) and the schematic I chopped up posted earlier. Also, the ground for the DCB1 is to the Mezmerize board.
Rush
Old 15th October 2012, 08:13 PM   #8186
buzzforb's Avatar
I just happen to have that very thing. Any change or diminishing ofsound, or did you get to listen, pre DCB1?
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 15th October 2012, 08:20 PM   #8187
It is better. Better sound stage, smoother. Still trying to find time to listen more. Only have 2 hours of low level listening now.
Rush
Old 16th October 2012, 01:06 AM   #8188
andyr is offline andyr  Australia
Yes, here is an earlier schematic that shows the output of the cap (0.1 uF) and 1 meg to ground ...
Rush
Hi Rush,
Can you tell me why you went for a 1Mohm res off the 2nd JFET Gate ... rather than, say, half that? IE. what advantage does 1Meg have here, compared to 500K?
Thanks,
Old 16th October 2012, 01:47 AM   #8189
Originally Posted by andyr View Post
Hi Rush,
Thanks,
159155
Divide your resistance then your uF into the above number and you have the 3 BD down roll off frequency. Multiply the 3 DB down frequency by 10 and that is how far the phase shift effects the frequency response.
So, 159155/1000000/.1 = 1.59 Hz x 10 = 15.9 Hz. All good, below 20 Hz
If, 159155/500000/.1 = 3.18 Hz x 10 = 31.8 Hz.
As the resistance goes down, the cap size goes up for the same roll off.
In the original circuit we had 2.2 uF and 1 meg, but I am using a DCB1 buffer with a 25k volume pot and a 220k input resistor. So an effective 22k resistance following the output cap.
The math, 159155/22000/2.2 = 3.29 Hz x 10 = 32.9 Hz phase shift
Really need to double the output cap, now that is getting pricey.
I see no advantage of using a lower resistance into a B1 buffer and I see great reasons to use the smallest cap that will do the job. The 0.1 uF coupling cap I used are $34 each, if I was looking a 4.7 uF of the same quality, would be $111 each and who knows if the bigger cap would sound as good as the smaller one, some folks would by pass the 4.7 uF with a smaller value and the cost keep going up.
I also don't have the physical space in my preamp for a larger cap anyway.
Rush
Old 16th October 2012, 02:00 AM   #8190
159155
Rush
Terrific - thanks, Rush ... now I understand your choice.
What caps cost $34 for 0.1uF? I have used Relcap RTX at about $9 in this position ... I presume yours sound a lot better?
Andy
Copyright ©1999-2013 diyAudio
