| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#8141 |
#8142 |
#8144 |
diyAudio Chief Moderator
Those are already 55pF junction capacitance big diodes, you wanna do that 110pF? Naah.
#8145 |
I have upgraded a bennic xpp coupling cap with a obbligato gold
for my surprise the sound become less transparent, bass Is rough not controlled the only little improvement are better highs resolution that Is for about 25 hrs listening do you think obbligato have time to burn In to play better |
#8146 |
IMO forghet to switch the FiFI off for a week and report back Please
I was going to try them so... |
#8147 |
Samoloko, you kept same value? What is that value?
#8148 |
thank you for reply
bennic xpp was 5,6 uF obbligato gold Is 4,7 uF |
#8149 |
See what happens in a week's time, if not satisfied yet try to bypass with FT-1 22n Russian small size Teflon. Only check those before you install for their leads condition. Test value is normal & not breaking signal with a little shake. Kept in Red Army logistics for many years.
#8150 |
Salas
Is FT-1 teflon better than MKP1837 In bypass 22n Is recommended for 2,2 uF or 4,7 uF |
