Simplistic NJFET RIAA
Old 2nd October 2012, 09:45 AM   #8091
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
How much second stage Miller is allowed for that graph?
Old 2nd October 2012, 09:49 AM   #8092
vgeorge is online now vgeorge  Greece
vgeorge's Avatar
Thanks for the advise Ricardo.
I will listen as is for a while and do some tests later on.
Will let you know the outcome.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 2nd October 2012, 11:23 AM   #8093
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Based on my experience I used 900p
RC
Old 2nd October 2012, 11:38 AM   #8094
Salas's Avatar
Hmm he has V grade and 39Rs plus a rather sweet treble Japanese cart and 4m listening distance. We will learn if he will perceive and in what way by his report. He is surely in good balance already.
Old 2nd October 2012, 11:48 AM   #8095
nhinstruments
RCruz's Avatar
Yes, I know you have been there so you know it is very good. The new 47k resistor difference is very small so it should not matter much.
Anyway the first graph looks way cool to me.
Maybe vgeorge wants to experiment... resistors in aligators are simple to use... we will learn from the outcome.
RC
Old 2nd October 2012, 11:57 AM   #8096
Salas's Avatar
There is always that wicked super fine tweak fixation lonely afternoon in times ahead...
Old 2nd October 2012, 12:02 PM   #8097
nhinstruments
RCruz's Avatar
Hehe... I always keep some 10p caps around to clip someware during the night...
RC
Old 3rd October 2012, 11:12 PM   #8098
Rush is offline Rush  United States
Salas,
Now that my pre amp is complete. I am fretting over the output coupling cap used in this design. I want to use the best and a V-Cap TFTF seems to be the favorite, that I can't afford. You have a 2.2 uF cap but into a DCB1 with a 22k ohms pot it really should be a 4 uF cap.
Normally with a single ended supply like the Simplistic NJFET RIAA you have no choice but to cap couple the output.
But with my setup, I do have a -DC regulated supply available.
What would we be able to do? How about a DCB1 with a trimmer resistor in the lower leg?
Rush
Old 4th October 2012, 04:32 AM   #8099
Salas's Avatar
2nd stage is sitting the buffer's gate at its VDS potential around 10V. So it centers there and carries it to the output. Now if the DC blocking could be transported to the buffer's input with a much lower value cap by using a 1-2meg gate to ground resistor for it, and there is a (-) adj supply available, we probably could make the output buffer like a DCB1 by matching the Jfets and the phono's (+) supply value available to the buffer after the RC at top right in simplistic's schematic. At least a quick thought. There are many highly regarded caps somewhat easier to pay for when the value is say 0.1uF or under. Maybe you would like a Jupiter as much or a Multicap RTX to give two opposite materials tech used between them examples. V-Caps I had put in a commercial phono that its owner bought for and asked me to fit, they did not impress me much for the money, still clean and smooth no doubt, could hear the upgrade. It had Hovland caps originally. Bigger upgrade was when I worked around the input circuit and tried a better suitable more linear tube type, cutting on noise also due to formerly excess gain. He adopted them after listening himself no matter how obsessed with his Telefunkens.
Old 4th October 2012, 01:43 PM   #8100
Default V-Cap TFTF
The V-Caps need a bunch of time on them to sound their best.
See attached capacitor shoot out, if you haven't already.
Rush
Simplistic NJFET RIAAHide this!Advertise here!
Copyright ©1999-2017 diyAudio
