Simplistic NJFET RIAA
Old 2nd October 2012, 06:05 AM   #8081
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
It maybe part the components quality part the subtle value fixes but we must not forget that George has speakers that let him hear things that our systems may well hide, and we probably can't relate directly to what exactly he hears more. I know because I had listened to them carefully since we had to judge and fine tune their 3way crossover we made. Those are large scale modular horns of the best ilk. Aided by high sens & power huge active subs. 4 way multi amplified system in total.
Old 2nd October 2012, 06:10 AM   #8082
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Salas, where is latest schematic. I have to mak emy brother a birthday present and he is a vinyl man. This seems like agood choice tome, although i am not to sure about the guy who came up with it For christmas he is getting the paradise. Both will try to unseat his conrad johnson. He likes glowplugs. People these days.
...Shape the sound , Man!
Old 2nd October 2012, 06:25 AM   #8083
Salas's Avatar
Originally Posted by vgeorge View Post
From what I remember FT-3 was a little bit more mellow sound, but I got more information and better highs from K-72. Maybe more accurate.
Also FT-3 was 100n and K-72 47n.
I got bigger improvement by changing these 2 resistors, something I didn' t expect to be really honest.
FT-3 comes across more mellow and K-72 a bit edgier when using tweeters in my experience but that may well be more info in reality that does not bother the Le' Cleach with the land mine size Great Plains driver you use almost over to 10kHz. It could be highlighting 3rd order nasties in one inch low crossed tweeters on the other hand. Which even the best are toys in dynamics VS THD comparison to such horns. So it can be working better for you. Those Z Foils are technically superior resistors indeed, but parts outlay must always go in tandem with the resolution that an installation can provide as a whole. I.e. logical in your case. So get/make the best speakers you can in good proportion to the room before spending lavishly in parts is a good rule of thumb for any of us IMHO. Orelli had great results too but look at his speakers and room treatment...Impressive. (#7849 & #7850).
Old 2nd October 2012, 06:35 AM   #8084
Salas's Avatar
Its all in the PDF linked from post #1. The mods you see I breadboard lately are not properly developed or confirmed positive yet. But some parts I needed are on their way.
Old 2nd October 2012, 07:21 AM   #8085
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Hi Ricardo,
here are the values I used :
R4=6,790K
C1=46,94nF
C2=15,080nF
C3=47nF
R14=46,93K
R1=180R
Salas, room treatment, I know, is on my shortlist for the winter!
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 2nd October 2012, 07:39 AM   #8086
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Ricardo,
R4=6,790K
C1=46,94nF
C2=15,080nF
C3=47nF
R14=46,93K
R1=180R
Hi vgeorge
I also need R13 and R5 real values.
RC
Old 2nd October 2012, 07:51 AM   #8087
vgeorge's Avatar
R13=2,19k
R5=998k
Old 2nd October 2012, 08:59 AM   #8088
nhinstruments
RCruz's Avatar
Perfect.
Using your actual values I see a slight rise in the highs and a recession in the upper bass as in the graph.
RC
Old 2nd October 2012, 09:03 AM   #8089
nhinstruments
RCruz's Avatar
You can experiment by lowering R4 to 6775ohm (by paralelling a 3M ohm) and then tune trebble according to your system by adding between 40p ~100p to C2.
You will reach the following result:
RC
Old 2nd October 2012, 09:07 AM   #8090
nhinstruments
RCruz's Avatar
But if you like your sound, do not touch it... Your setup is very good... as is the result is 0.05dB off target
RC
Simplistic NJFET RIAAHide this!Advertise here!
