Simplistic NJFET RIAA - Page 807 - diyAudio
Old 30th September 2012, 11:03 AM   #8061
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Obbligatos are very good but plain good. MR are high range. Silver in Oil is the most I would buy from Mundorf. Those hybrid oilers you keep them away from heat in valve amps btw. Clarity has a TC range of can style HV PP caps I saw, much cheaper than MR. Maybe good for rectification filtering to SSHV2 in #26 preamps they use that reg a lot.
Old 30th September 2012, 11:03 AM   #8062
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by Salas View Post
Could be with big caps. We should tap them when connected on the scope alone. Because if we tap them phono connected, maybe other stuff rings on the high gain board too.
In my initial Benz riaa build that used a british hand made pcb, I could hear noises just by tapping the ft3 coupling caps, the decoupling EL caps or the output caps.
Now my p2p builds are much sturdier and I glue the caps to the board so no microphony at all.
I do not think Mundorfs are more microphonic than any other caps.
RC
Old 30th September 2012, 11:13 AM   #8063
Salas's Avatar
Tie wraps and some 3M double face tape can do wonders in general.
Old 30th September 2012, 11:14 AM   #8064
Salas's Avatar
...Or the messy hot snot gun liberated.
Old 30th September 2012, 12:45 PM   #8065
nhinstruments
RCruz's Avatar
That is precicely what I use
RC
Old 30th September 2012, 12:48 PM   #8066
nhinstruments
RCruz's Avatar
A good alternative to the supremes might be these Intertechnik cap plus: https://www.intertechnik.de/Shop/Cro...us/1768,en,280
And if you need a fuller sound, these are quite good https://www.intertechnik.de/Shop/Cro...SN/1768,en,277
I use these Tin foil caps in my pedja buffer, producing a magical full sound.
RC
Old 1st October 2012, 03:06 PM   #8067
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Just changed the Rload and the 47K resistors to Zfoils.
I was not expecting this sound improvement!
Got more clarity and transparency, as well as more information.
Not cheap but I think it was money well spend at the end.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 1st October 2012, 03:22 PM   #8068
merlin el mago's Avatar
Welcome
Old 1st October 2012, 03:23 PM   #8069
Try FT3 for interstage.
Old 1st October 2012, 03:30 PM   #8070
vgeorge's Avatar
What I use is better than FT-3, had FT-3 before.
http://www.ebay.com/itm/Russian-Tefl...item33706a6ffb
Copyright 1999-2017 diyAudio
