Simplistic NJFET RIAA
Old 30th September 2012, 09:41 AM   #8051
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by RCruz View Post
Initialy I just swaped the output caps. I had 4u7 obbligatos and now I have those uge Clarity. I imediately noticed a uge increase in high freq definition, stage size and extension.
Then I swaped the Mundorf MKP in the output zobel of the V12R by the obbligatos and everything became more refined. Finally I bypassed those obbligatos in the zobel with 15p SM and bingo.... Super sweet with just a little bit of high freq sparkle.
As a bonus, bass became more detailed letting us hear lower freq info that was buried before.
Total cost of the upgrade was around 100euros (the cost of the clarity caps)
I will listen to some records and let you know my subjective opinion bksabath.
This build has 48dB at 28V. It was already so good I believed it could stand this cap upgrade. Now it is really incredible.
Are those Clarity caps their expensive MR range?
Old 30th September 2012, 09:45 AM   #8052
R.I.P.
RC,
could you turn that description into a schematic?
regards Andrew T.
Old 30th September 2012, 09:54 AM   #8053
Bksabath is offline Bksabath  United Kingdom
Banned
I have in my build M Caps Supreme (2,2 uF nothing to expensive so far) I have noticed that those suffer from microphone effect; if you tap them they produce noise at the output.
Which is no good IMO
I was wondering if this is common around the Mundorf range and if this is common with large "designer" caps.
I look forward to get your impressions and was wondering if we can pick a few records that we could all use and compare with.
I found one (got it new in sealed box last Thursday) that has quite a few nice passages of guitar pretty well recorded and same other passages where stage spatiality is at the forefront.
And may be worth a few bobs in the future....
Old 30th September 2012, 10:10 AM   #8054
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Here you have:
RC
Old 30th September 2012, 10:17 AM   #8055
nhinstruments
RCruz's Avatar
I sugget this copy of City of Eyes.
Sumptuous soundstage on a beautifully detailed guitar recording.
RC
Old 30th September 2012, 10:18 AM   #8056
nhinstruments
RCruz's Avatar
These are MR.
Not so expensive as the Mundorf SGO but quite good.
RC
Old 30th September 2012, 10:32 AM   #8057
nhinstruments
RCruz's Avatar
Salas
If I use 27k for vref, I will need 1.27mA to get 35Vout.... better
Hope the bass does not suffer much.
RC
Old 30th September 2012, 10:38 AM   #8058
Salas's Avatar
These are MR.
I have used SGO for that build I had made for my friend with the Euro12K cart, I did not find them impressively better than their lower supremes price wise. More refined but not 160Euro refined he payed them. The MR have some back up of scientific research at Salford Uni non the less.
Old 30th September 2012, 10:44 AM   #8059
Salas's Avatar
Could be with big caps. We should tap them when connected on the scope alone. Because if we tap them phono connected, maybe other stuff rings on the high gain board too.
Old 30th September 2012, 10:55 AM   #8060
nhinstruments
RCruz's Avatar
Comparing the MR with the obbligatos, I really find them much more detailed enabling a wider soundstage. Costly but effective indeed.
This proves that the Simplistic is so good it can benefit from better components.
As I recently swaped my 16x preamp by the DCB1, I need a bit more gain in the front end... that is why I am building the new cascoded simplistic
It will take some time because my budget is now scarce but in the end it will contribute to my experience.
As you know, I recently built a bjt transimpedance / current amp riaa and I did it mostly because I needed to know how far could we go from the utter simplicity.... and what subjective quality gains could we get with such a complex design.... Now I know
RC
Simplistic NJFET RIAAHide this!Advertise here!
