| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#8031 |
Salas, i will publish a graph from Sansen that shows what is going on in general.
#8033 |
diyAudio Chief Moderator
No, this is only indicative IMO. The K170 Vds under the BF245C or J310 was 2.7-3V in breadboard test. That gets you to 35pF Ciss. Crss goes to 10pF at that Vds. If it was without cascoding it could be around 230pF Miller effect with the gain and Rs used. I hope for 4 to 5 times reduction with JFET cascoding in this non perfect world, and it remains to be measured. With a BJT and higher Vds like in first stage it can go closer to elimination and nearer to just Ciss.
#8034 |
#8035 |
Here we go, sorry the scan was not easy, this book has a HUGe size.
#8036 |
0255 shows that G/BW is not affected so when i trust Bruno Putzeys the speed does not go up when G/BW is the measure of speed. Se " The F Word" in Linear Audio.
#8037 |
The question is " What is a low frequency in this context ? "
#8038 |
Whatever is 10-20times less than the circuit's bandwidth I guess.
#8039 |
The open loop gain falls of with 6dB octave usually so it depends on the feedback factor,
degeneration or GFB come to mind. What is clear is that the cascode gives more gain but also lower open loop bandwidth. In total, given the same resulting gain the cascode is lower in distortion because we win more gain then we loose open loop bandwidth. |
#8040 |
0214 last paragraph is actually the B1 and output buffer in this test phono in words.
