Simplistic NJFET RIAA - Page 784 - diyAudio
Old 17th July 2012, 05:34 PM   #7831
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its jumping. Is there DC on its MM input?
Old 17th July 2012, 05:48 PM   #7832
merlin el mago's Avatar
My DMM can't measure but flashes the - with 0 Volts
Old 17th July 2012, 05:56 PM   #7833
1kHz sinu. 0.2V/cm both channels same wave
Old 17th July 2012, 06:14 PM   #7834
Salas's Avatar
I suggest you check your TT. MC pre pre, and SUT to another MM stage of friend's if possible, or make a typical stage from cheap op amp datasheet. Nothing makes sense till now, contradicting evidence, that can't make us useful opinion givers.
Old 17th July 2012, 06:15 PM   #7835
DMM is jumping between 0.2mVdc & 0.3mVdc at tape output when I take the measurements with scope
Old 17th July 2012, 06:18 PM   #7836
Salas's Avatar
Nothing serious.
Old 17th July 2012, 06:41 PM   #7837
I forget that I have one cheap opamp MM battery powered, connected the Low MC pre-pre to MM and no buzz, both channels sounds music perfectly well congratulations & thanks Salas for suppot & to design this little jewel.
Old 17th July 2012, 08:27 PM   #7838
Salas's Avatar
Send me the Rotel to personally blow it up, it drove us crazy.
Old 17th July 2012, 08:30 PM   #7839
Yes it droves us crazy, I always suspected of it
I give a chance to the Rotel for integrated amp without phono MM input, I'm waiting to have a LS3/5A in the future if I have lucky but I suspect can't drive the loudspeaker due to it's high impedance but always can drive it with EB Millenimum 75W RMS Class A monoblocks.
Old 17th July 2012, 08:34 PM   #7840
Salas's Avatar
OK, you blow it up then and you save the shipping cost.
Copyright 1999-2017 diyAudio
