Simplistic NJFET RIAA
Old 11th July 2012, 08:31 PM   #7781
Milos P. is offline Milos P.  Serbia
No test record, what would you recommend?
I checked with protractor (two point) today and all seems fine.
Arm cart geometry I don't know how to test .
Sorry to hijack , this has nothing to do with the Simplistic pre amp, I'm sure that preamp is just fine.
Old 11th July 2012, 08:37 PM   #7782
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Get the HFNRR test record. Its very revealing of antiskating bias, high modulation tracking, cart-arm resonance etc. Have you got too much treble in general, or is it of transient nature like sibilance only? Have you got any magnification means to check the diamond isn't grated or chipped?
Old 11th July 2012, 08:49 PM   #7783
Rush is offline Rush  United States
Originally Posted by Milos P. View Post
Hi
where can I look for the source of the sibilance that I have? The rest of the components of my system can be ruled out as there is no sibilance when I play cds, for xmpl. I have Grado black that needs only 47k load according to manufacturer, no loading cap. I tried various loading caps from 10p to 250p but no luck. Instrumental music sounds fine, no extra hi range or it is less noticeable so it is no problem.But on some vocal inclusive vynils it really gets anoying.I'm sure this sibilance is not product of the preamp, yet I don't know where to look for the cure any more. Apart from the preamp, what else can introduce this nasty distortion?
As far as I understand 100n cap in the preamp is not part of the RIAA, it is just DC block?
Thank you
I have noticed poor record quality in the sibilance (vocals) of modern vinyl records these days in the USA. Adele21 is unlistenable to me. I took it to my local hifi shop and played it with a $10,000 turntable/arm/cartridge, Ayre pre-amp and power amps, Wilson Audio speakers. Could listen to it there either.
Try an older recording and see what it is like.
Rush
Old 11th July 2012, 08:51 PM   #7784
I would not say that there is too much treble in general- not at all. Instrumentall music from jazz to dub step- sounds just fine. It is sibilance of transient nature only. No magnification means, just 5 times lamp thing...
Old 11th July 2012, 09:17 PM   #7785
Salas's Avatar
Had anybody tested this kind of gadgets? A 200X or something wand type a friend got was grainy enough.
USB microscope gadget.
Old 11th July 2012, 09:25 PM   #7786
atupi is offline atupi  Romania
Preparing an order to PCX i want to know what affordable boutique part can i order for the resistors in the RIAA (6k8, 47k) ?
For the cart loading cap and resistor what kind of components to choose ?
Thanks!
Old 11th July 2012, 10:12 PM   #7787
Salas's Avatar
Z foils if only 4 pcs, it does worth it there.
Old 11th July 2012, 10:13 PM   #7788
Salas's Avatar
Z foils if only 4 pcs worth it there.
Old 15th July 2012, 11:44 AM   #7789
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Question Low MC pre-pre I need help
Connected today the Simplistic Low MC pre-pre left channel big buzz right channel without sound, no music
Wich steps have I to follow to fix the issue?
N.B. MM where is connected the MC pre-pre is going on OK is tested before.
Old 15th July 2012, 12:08 PM   #7790
Interesting device to check solder joints & pick-up cartridges.
Simplistic NJFET RIAAHide this!Advertise here!
