Simplistic NJFET RIAA - Page 775 - diyAudio
Old 2nd July 2012, 05:46 PM   #7741
merlin el mago's Avatar
What do you want that I do: disconnect Q4 & R3 + R4 connected to R1?
Old 3rd July 2012, 10:07 AM   #7742
Without cap multiplier, measuring C4 to GND 8,97V but I believe isn't a good reg. for a pre-pre MC....
Old 3rd July 2012, 04:34 PM   #7743
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Why you want to take out the cap multiplier. Use the circuit as designed. There is a chip reg at 9V then a filter. The cap multiplier filter eats the reg's noise by much and brings down the voltage also. Its designed to work form that final voltage.
Old 3rd July 2012, 04:46 PM   #7744
With cap multipler can't reach 9V
Old 3rd July 2012, 04:58 PM   #7745
Salas's Avatar
I repeat. The amplification circuit is not designed to work from 9V, but from about 7.5V as after the multiplier.
Old 3rd July 2012, 05:23 PM   #7746
I'm sorry to don't understand you before, thanks again.
Old 7th July 2012, 03:33 PM   #7747
Build & measurement pics Low MC pre-pre
1st pic right channel
2nd pic 1kHz direct audio generator 30dB attenuation
3rd pic lefht channel
probe x1
4th pic Low MC pre-pre including capacitance multiplier
5th pic R-Core separate PSU
Are the measurements OK?
Old 7th July 2012, 03:42 PM   #7748
Salas's Avatar
I can see higher output than input. How much exactly, channel matching looks good, you know your numbers.
Old 7th July 2012, 03:50 PM   #7749
Yes channel matching seems good, how can calculate the gain?
Old 7th July 2012, 05:13 PM   #7750
Voltage gain in dB = 20 log Vout/Vin
Now I only need to know how calculate the volts with the scope, help please?
Copyright 1999-2017 diyAudio
