Simplistic NJFET RIAA
Old 10th June 2012, 09:54 PM   #7721
rclourenco is offline rclourenco  Portugal
Thanks Salas and Andrew for your comments and instructions.
Did some tests on a sample of 28 transistors.
I used a 9V battery with 100R in series to Drain, with G and S shorted to battery negative.
Measured also resistance from D to S and found always values in the region of thirties ohms.
The values were read with my DMM on both resistor terminals as bellow:
- 0,840V. - 0,984V. - 0,647V. - 0,938V
- 0,770V. - 0,944V. - 0,830V. - 0,804V
- 0,730V. - 0,638V. - 0,900V. - 0,965V
- 0,684V. - 0,957V. - 0,655V. - 0,925V
- 0,720V. - 0,884V. - 0,720V. - 1,014V
... And so on.
What do you think? If I use I=V/R, in one of the values, say 0,840V divided by 100R, I get 0,00840A. Is this correct?
I believe that the higher values are the most suitable, correct?
Thanks once more, I will try to show you my wok as this goes on.
Old 10th June 2012, 11:08 PM   #7722
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Obviously correct. 8.4mA.
8-8.5mA are working in the PDF circuits OK.
Old 11th June 2012, 06:01 AM   #7723
Old 11th June 2012, 10:05 AM   #7724
R.I.P.
How well did your battery hold it's "starting" voltage till the completion of the 28 measurements?
If it started @ 9.0V and held at >8.9V till the end then Vds was in the range ~8.3Vds to 7.8Vds. Good enough for rough batching to 2 sig fig.
However if the battery voltage fell to ~8V, then the Vds range changes to ~8.3Vds to 6.8Vds. This range of Vds being very significantly different from the 10Vds specified for Idss will increase the "errors" in your results and between your results.
A quick scan of your 20 posted results shows Idss between 6.3mA and 10.1mA
regards Andrew T.
Old 11th June 2012, 07:50 PM   #7725
Just measured the battery and it's 9,09V!
Old 15th June 2012, 08:26 PM   #7726
Milos P. is offline Milos P.  Serbia
Hi Salas,
I'll be building one more preamp for the second arm I'm about to add to my TT. This time, HO MC Micro Benz Silver, 2mV cartridge will be used. I was wandering shall I go RIAA-V1102F0 route again or is there a more suitable design of yours, for 2mV cartridges?
Thank you
Old 15th June 2012, 08:29 PM   #7727
Salas's Avatar
That in the PDF is OK. If you will need say 45dB instead of 43, you can scale down first stage's Rs a bit.
Old 15th June 2012, 08:35 PM   #7728
OK, thaks a lot.
Old 23rd June 2012, 11:48 AM   #7729
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Question pre-pre low MC 20dBs
How can be modified the pre-pre low MC 20dBs schematic to run with batteries?
File Type: jpg Salas Simplisitic pre-pre Low MC 20dBs.jpg (253.1 KB, 232 views)
Old 23rd June 2012, 11:52 AM   #7730
R.I.P.
Remove every component to the right of C4.
Apply a 9V battery.
C4 could probably be increased to 100uF.
regards Andrew T.
Simplistic NJFET RIAAHide this!Advertise here!
