Simplistic NJFET RIAA
Old 6th May 2012, 06:16 AM   #7591
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Sounds like a bargain deal for a spare at least, Technics produced no slouch MM on its own back in the day. If yours carries a Technics one still.
Old 6th May 2012, 10:13 AM   #7592
chalkandtalk is offline chalkandtalk  United Kingdom
Wow that looks stunning. I see someone has used it on a Technics linear tracker. Seems like a no-brainer.
Old 6th May 2012, 10:40 AM   #7593
R.I.P.
Mount the RIAA inside the turntable package.
Keep the wires from the arm to the RIAA as short as possible, while maintaining flexibility to not hinder turntable set up.
regards Andrew T.
Old 6th May 2012, 12:22 PM   #7594
atupi is offline atupi  Romania
Salas, what is the output impedance of this nice preamp that i have also built?
Old 6th May 2012, 04:35 PM   #7595
keantoken is offline keantoken  United States
keantoken's Avatar
I am looking for a new T4P cartridge, but I keep getting confused. The AT92ECD is supposed to be the best below $50, but I can get the AT311EP for the same price. At the same time, I heard the 92ECD is better. Not sure what to think about all this. The 91ECD has a .4/.7 instead of .3/.7, so theoretically it will pick up less noise? But I'm not afraid of using wood glue, maybe I shouldn't worry about noise...
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 6th May 2012, 06:03 PM   #7596
keantoken's Avatar
Also, it looks like you could buy different styli that would fit into all of those AT carts. For instance, put the AT3482P stylus into the AT92ECD cart, for better or worse... Haha, has someone tried this?
Old 6th May 2012, 07:56 PM   #7597
Salas's Avatar
60-70 Ohm for BL grade IDSS used.
Old 6th May 2012, 10:24 PM   #7598
Salas's Avatar
Kean don't know really, 311EP is supposed to be the top dog as poised in gamut by AT themselves, isn't it? It could be very possible some less quality arms and TTs find a fatter stylus more forgiving though. Someone with direct experience should give real clues.
Old 7th May 2012, 01:45 PM   #7599
Spent a few hours looking for reviews of these carts with various posh shaped stylii. Unfortunately I haven't been able to reach a conclusion either. I'm very tempted to spend 250 euros on an Ortofon X1.
Old 7th May 2012, 01:47 PM   #7600
Salas:
Will I need the pre-pre if I plug a medium output MC cartridge into the MM RIAA?
I believe the output of the cartridge is around 0.5mv.
Simplistic NJFET RIAAHide this!Advertise here!
